new aleph to be built..?
Old 28th August 2003, 09:49 PM   #1
george a is offline george a  Australia
Default new aleph to be built..?
Hi all
I may well just try building an aleph using about 12 2sk134 TO3 mosfet as per moamps effort etc.
But that leaves me with 12 of 2sj49 mosfet (compliment to 2sk134) to find a use for.
any suggestions?
Can "a negative" version of an Aleph be built with these-
you can probably tell i'm possibly getting out of my depth.
Apologies Mr. Pass... you must be shaking your head.
regards to all
george a
Old 29th August 2003, 03:08 AM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
The negative would work just fine. Simply use reverse
polarities on all parts.
Old 29th August 2003, 08:58 AM   #3
moamps is offline moamps  Croatia
Maybe this schematic .........
Old 29th August 2003, 09:17 AM   #4
joensd is offline joensd  Germany
What about ZenV5?
Itīs complementary design, very simple and you could lower gain, parallel devices and add aleph input stage or whatever you like.
Old 29th August 2003, 12:06 PM   #5
Or left mono block with Pch FETs, right with Nch FETs !?
Old 29th August 2003, 12:22 PM   #6
Thank you all for your replies.
Moamps , did you just happen to have the schematic lying around?
The Pos & Neg monobolc idea also passed through my mind, I wonder if they would sound different (mirror image..)
Nelson thanks for your prompt and (since it came from you ) encouraging reply.
Looks like I have another project to ad to the list of things to do.
Regards to all.
ps Nelson did you have anything to do with an old Threshold Moving Coil head-amp some 20yrs ago ?
(had 7 of paralleled 2n4401 in it)- an excelent (to my ears at least ) unit
george a
Old 29th August 2003, 12:37 PM   #7
I have 8 pcs. 2SJ49 too. This schematic was like idea in my head long time. Today I was checking my drawing skills.
I wonder too.
Old 29th August 2003, 05:51 PM   #8
Anorgan is offline Anorgan  Croatia
Anorgan's Avatar
Default Splitting mosfets
Hi, I was just thinking, could you make a Zen v4 with a bunch of mosfets to "split" heat - is there a schematic for such things. I think it's called cascading, but I'm not sure. It could save some money on the heatsinks. THX for reply.
Old 29th August 2003, 06:09 PM   #9
The one and only
You can parallel quite a few Mosfets, giving each its own
Gate and Source resistor, and this can get you to much higher
power simply.
Old 29th August 2003, 06:18 PM   #10
JOE DIRTŪ is offline JOE DIRTŪ  Canada
JOE DIRTŪ's Avatar
Nelson what would you say is a safe approach to a parallel approach of the fets...I have done the math on the drivers but dont want to intrude on your design.....if you have this info on your site I retract the question but I am simply asking for the question at hand
DIRTŪ
new aleph to be built..?Hide this!Advertise here!
Aleph 2 Built But Some Questions Remaining hifileslie Pass Labs 3 4th August 2009 06:30 PM
wanted built aleph x or f5/f3 boards slr 5000 Swap Meet 2 12th March 2009 08:41 AM
FOR SALE: Built-up Aleph 5 PCB's DirkD Swap Meet 8 25th April 2005 07:24 AM
Has anybody built an Aleph-x to this spec??? D3 Pass Labs 58 16th June 2004 06:08 PM
Anyone built an Aleph L?? Mark A. Gulbrandsen Pass Labs 5 29th September 2001 05:03 AM
