Burning Amp BA-3 - Page 89 - diyAudio
Old 9th November 2012, 03:15 AM   #881
The Space Egg Corp's Avatar
Wire-wounds ARE COOL !!! ( especially the big ones, with small loads ! ).
Interesting to read Mr. Morgan Jones's comments on WW's of recent...
...very low value one's do have a VERY small inductance...he say's ( a few uH's )...
...ie. like Variac says...the one's people use in PSU's.
Larger one's...according to Morgan Jones...have very little inductance at all...
...ie. over 1/4K or so...series signal-path ones, loads etc.
Heat-cycle on a low oven-temp, with that pizza warm-up...BINGO...stable values, low noise...&...err...PIZZA !
What could be better than that...
...love 'em both.
BBA-3 looks 'tasty' as well !
Cheers
Si.
Old 22nd November 2012, 04:00 AM   #882
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
Sorry for " OFF TOPIC "
Can someone help me ?
Where i can find the BBA3 PCB like this ?
I need 2 SET " Green " PCB
Please PM or Email me
Best Rgds
Old 22nd November 2012, 06:00 AM   #883
just another
wintermute's Avatar
official boards are avaliable through the diyAudio store. FE boards here --> P-BAGSN-1V20 - Burning Amplifier Gain Stage for BA-3 (Requires bias boards and output stage; Makes 2 channels; Rev 2.0) - Burning Amplifier Series - Power Amplifiers - PCBs though I am red/green colourblind, I'm pretty sure the boards are red
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 2nd December 2012, 01:14 AM   #884
timbarnes's Avatar
Default Something weird happening with my BA-3
I'm having a curious problem with one channel of my BA-3...
  • When I turn the amp on, the left channel will often appear to be dead.
  • If I turn up the volume (passive unit before the BA-3), the sound will suddenly turn on.
  • If I then turn it back down to a normal level, it continues to play, but it will sometimes just go off again later.
  • The same remedy will bring it back on again.
Any ideas where I should look for problems?
Thanks,
tim
Townshend Rock III, Hagerman Bugle 2, Naim CD5i, RPi Volumio, MiniDSP, Elliot P101, IRS2092, Parham Pi Sevens & Pi Three
RC Preamp (in progress), Pass BA-3 and F4, DIY Silver cables, Open Baffle BOFU, DIY subwoofer, GainClone, o2 Headphone Amp
Old 2nd December 2012, 10:48 AM   #885
Probably not the Power Amplifier.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 2nd December 2012, 02:47 PM   #886
timbarnes's Avatar
I agree. The F4 seems fine. The BA-3 is my preamp gain stage in conjunction with a passive select/attenuator box.
The problem only occurs with the BA-3 in circuit.
Tim
Old 2nd December 2012, 03:44 PM   #887
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
We ran into this sort of problem in mixing consoles in live sound, it usually ended up being either (1) a cold solder joint, (B) a loose or dirty connector, (III) a capacitor, or (d) a wiper making bad contact in a potentiometer.
Maybe look at the electrolytic caps on that channel of the BA-3 board. Also give the preamp the "slap test", see if physical stimulus affects the problem.
Old 2nd December 2012, 03:58 PM   #888
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Mr. dB View Post
Also give the preamp the "slap test".....
yeah, give a good slap and tell it to behave
sorry, couldn't resist it ....have a picture been posted ?
[*]If I turn up the volume (passive unit before the BA-3), the sound will suddenly turn on.
ah ! look at your pot then
Old 3rd December 2012, 12:08 AM   #889
timbarnes's Avatar
I get the same behavior with two different passive preamps, so I don't think it's the pot. I think it's probably a bad solder joint - the BA-3 is sensitive to being slapped. But I've tried resoldering a couple of times and I can't see any bad joints. Need to try again, I guess.
Today for some reason it's been stable and great to listen to...I guess it's been reading my posts and fears for its life
First picture is of the two units closed; second is the BA-3 and third is its power supply. The BA-3 is configured as a gain stage, following a passive preamp, and preceding my stereo F4.
tim
Old 3rd December 2012, 01:39 AM   #890
william2001's Avatar
Once you catch it when it's dead, check the voltages on R3, R4 (~80mV), and R10, R11 (~1V) to see if you have current flowing through those elements. If it's alive but still no sound, maybe a bad RCA connection or something, or a solder joint as you said. An o-scope would be real useful at that point if you had access to one.
Burning Amplifier BA-1 Variac Pass Labs 356 17th January 2017 11:54 PM
Burning Amplifier BA-3 Nelson Pass diyAudio.com Articles 39 14th October 2016 11:36 AM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
Copyright ©1999-2017 diyAudio
