#841 | |
The 600 ohm was the combined total drain resistance, but that doesn't matter now that you have put in the new pot. |
#842 |
Hi
Okay thx, i give it a try and make some listen tests, and ma by fiddle with q1-2 Nkdk |
#843 |
Hi there, i was hoping that someone could point me in the right direction regaring some measurements on the front end. I have a dip/overshoot on the negative curve that i would like to understand.
Voltage on the resistors are: Left R3/R4 = 64.66 - 64.69mV R10 = 1.042 V R11 = 1.037 V Right R3/R4 = 65.08 - 65.10mV R10 = 1.038 R11 = 1.036 Here are som waveforms from the scope, the blue ones are for left channel and red for right. The input is 2Vp-p @ 5k, 50k and 100kHz. Measured across R13. 2Vpp_5Khz_Left.gif2Vpp_5Khz_Right.gif 2Vpp_50kHz_left.gif2Vpp_50kHz_Right.gif 2Vpp_100Khz_Left.gif2Vpp_100Khz_Right.gif |
#844 |
fiddle with P3
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#845 |
Hi
![]() Would some one help me out here I don't know where to connect the connection from the ba 3 to the bias board ,Like what connects to D+ or D- or S Thanks ![]() ![]() NS |
#846 |
#847 |
who made these pcbs ?
#848 |
Diyaudio store
![]() Output of One side of the BA-3 frontend to D (GS) and ground G of One bias board, the same with the other output of the BA-3 Frontend and the other bias board. D+ and D- are Only for the bias and S is the feedback sensing the bias current.
and the First W tt is......a really First Class P SS Idea !
#849 |
so there must be a blog somewhere ?
D+ and D- are reminding me on BA3 balanced sorry - I just didn't follow birth of pcbs
#850 |
Unfortunately Nelson's PDF and the bias and output board nomenclature are a bit different
I always had to think twice when connecting these parts and often.......did it the wrong way. In this case D+and D- refer to the drains of the upper and lower outputstage and their bias. D (GS) !GS means gainstage, is the real input and the ground point nearby is for he shielded cable.
| Burning Amplifier BA-1 | Variac | Pass Labs | 330 | 18th May 2013 03:06 AM |
| Burning Amplifier BA-3 | Nelson Pass | diyAudio.com Articles | 31 | 14th April 2013 03:02 PM |
| Burning Amplifier BA-1 | Nelson Pass | diyAudio.com Articles | 3 | 24th October 2011 02:53 AM |
| WTB: Burning Amp BA-1 or BA-2 | jdubs | Swap Meet | 0 | 23rd March 2011 03:16 AM |
| FS: two burning amps (one each BA-1 and BA-2) without drivers | Eric Weitzman | Swap Meet | 15 | 17th February 2010 02:35 AM |
