Old 28th May 2012, 05:14 PM   #751
Banned
You could also consider paralleling constant current sources with one of the output devices
Old 28th May 2012, 10:18 PM   #752
buzzforb's Avatar
As in Leaving Class A" article?
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 28th May 2012, 10:29 PM   #753
Banned
My memory is bad, but yeah I am reasonably sure Nelson discussed it in that article.
Old 28th May 2012, 10:35 PM   #754
buzzforb's Avatar
Little bit above my head, TBO. Interested though. Got to many pokers in the fire anyway. In about 2 months, it will be time to finalize my system, that will be on the agenda .
Old 28th May 2012, 10:40 PM   #755
Banned
Well just compare BA3 front end with BA2 output stage vs BA1 output stage.
Then think BA1 output with more grunt is what you will get with BA2/current source. It is a bit of a compromise for difficult/reactive loads.
If you don't need the grunt, then BA1 output or Aleph output is all you need.
With or without these tweaks the amp will sound sensational.
Old 28th May 2012, 10:52 PM   #756
buzzforb's Avatar
I watch in earnest. No feedback naked F4/Ba output has a sweet sound to it. MOre musical than F5 for me. I havent messed with P3 on F5t yet. That will come when i get soundcard up and running. Too little time!
Old 1st June 2012, 01:10 PM   #757
Hi buzzforb,
We were talking about thermal drift on the BA-3 but I don't think we decided how much heatsink was enough. I was getting a variable dc offset, certainly not rock solid, using the same heatsink as in Nellson's picture in his build plans except mine had two more prongs.
Did you end up using something more substantial? Technical details or a picture would be appreciated.
Chris
Old 1st June 2012, 02:07 PM   #758
buzzforb's Avatar
If you are still getting drift and your fets are cool or at least warm to the touch, it is probably more circuit related than the heat related. I believe this is the primary reason for such a large cap. Mine is torn down right now, as I am in the midst of the F5T, but will be reinstalled on the sinks when I am done testing.
Old 4th June 2012, 03:56 PM   #759
Kamel is offline Kamel  Germany
Send a message via ICQ to Kamel
is there any issue in decreasing R10/R11 to 10Ohms, to double voltage gain? Are there Problems with oscillations?
Bias Point will be adjusted to 70mA per Device and R13 an 12W type will be used...
Best regards, Felix
Old 14th June 2012, 03:05 AM   #760
Banned
Default Panasonic FR
Has anyone used panasonic FR caps? They look significantly better than panasonic FC. I am looking at ordering some for C1 and C2. However I have noticed 2 different part numbers for the same cap, but can't see what the difference is.
Burning Amplifier BA-1 Variac Pass Labs 330 18th May 2013 03:06 AM
Burning Amplifier BA-3 Nelson Pass diyAudio.com Articles 31 14th April 2013 03:02 PM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
Copyright ©1999-2013 diyAudio
