Burning Amp BA-3
Burning Amp BA-3
Old 20th March 2012, 11:53 PM   #721
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Burning Amp BA-3
Fawlty ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 20th March 2012, 11:55 PM   #722
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Depends what he means by that.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 21st March 2012, 12:00 AM   #723
Zen Mod's Avatar
Burning Amp BA-3
Old 21st March 2012, 12:24 AM   #724
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Towers. So increased bias doesn't increase linearity. Why does it have the affect of decreasing distortion in many cases?
...Shape the sound , Man!
Old 4th April 2012, 06:52 PM   #725
mikegranger is offline mikegranger  United States
Originally Posted by buzzforb View Post
put small caps on output of dcb1 and see if that helps.
Greetings,
This is my first post. I have been reading/learning here for a while, but didn't have anything to contribute until now.
I built a hard wired version of the BA-2, and experienced a brief turn-off noise from the amp. I took a look at the outputs with my scope, and found that there was a very high frequency oscillation transient causing the sound. After some puzzling over the problem, on a hunch I moved the gate stopper resistors, connecting them directly to the mosfet gate leads. They had been connected to the gates via about 1.5 inches of wire. This completely solved the problem. The amp had shown no instability while powered up. I later noticed that Papa mentioned that mosfets can make very good oscillators with just a short length of hook up wire on their gates. I don't know if this happening with your amp, Yap BC, but it might be.
Thanks Papa. You are a great teacher!
Old 15th April 2012, 03:12 AM   #726
neoinc is offline neoinc  Singapore
neoinc's Avatar
Burning Amp BA-3
Am i correct that i would need two BA3 boards for a stereo Balanced BA3? If i also want inbalanced inputs, is there way to implement it?
Old 15th April 2012, 05:09 AM   #727
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Burning Amp BA-3
yes, and yes
how to do it balanced have been shown
but not how to wire the single ended to balanced input
I would surely like to see it too
Old 16th April 2012, 06:36 AM   #728
Yap BC is offline Yap BC
Default Turn-off noise
Originally Posted by mikegranger View Post
Greetings,
I am using a BA-2 board purchased from DiyAudio Store. I supposed that the components' placement and tracks' length on the board would have been optimized to prevent oscillation.
Since I do not have a scope, I just used some trial and error methods to rectify it. I guessed that the main power supply switch in my amp could have contributed to the problem during turn-off, so I just added some X2 capacitors with a total value of 0.1 microfarad to the power on-off switch to improve on the suppression during turn-off. No more turn-off noise. Even occasionally when it happens, the turn-off noise is very much reduced. Anyway, thanks for your suggestion.
Old 16th April 2012, 08:13 PM   #729
Zen Mod's Avatar
Burning Amp BA-3
wrong guess , except if you deliberately want mute function
for unbalanced input , just ground neg input
RCA hot to +in , RCA gnd to gnd
Old 16th April 2012, 08:39 PM   #730
Burning Amp BA-3
corrected
Originally Posted by Zen Mod View Post
wrong guess ......
Burning Amp BA-3Hide this!Advertise here!
Burning Amplifier BA-1 Variac Pass Labs 356 17th January 2017 11:54 PM
Burning Amplifier BA-3 Nelson Pass diyAudio.com Articles 39 14th October 2016 11:36 AM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
