Burning Amp BA-3
Burning Amp BA-3
Old 5th March 2012, 09:53 AM   #701
R.I.P.
Let's hear from more builders of the BA3. See what they find with output offset stability.
It's just possible that a DC servo is required to control the offset, but at this early stage, further investigation is required to find out why offset is drifting so much.
regards Andrew T.
Old 5th March 2012, 10:24 AM   #702
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Andrew, I dont doubt what you are suggesting, but if Nelson published it, it is probably rock solid if set up correctly. I think in both cases, the bias was probably set early and not readjusted. I have had zero trouble with drift.
Old 5th March 2012, 10:29 AM   #703
buzzforb's Avatar
Originally Posted by Yap BC View Post
It seems like some of you are also having this thermal drift problem. I had already replaced the single turn pots to multi-turns type and setting the dc offset is very much easier now except that it will drift off due to thermal change. Even after a warm up of more than 1 hour, it will drift off after putting back the top cover. Looks like the only way is to have bigger heatsinks for the FETS.
Check the heat of your sinks and see how hot they are getting. Try it after you have the lid on in the situation where it drifts. It could be heat related. What is the Idss of your input fets? what current are you showing on the Jfets when the amp is on.
Old 5th March 2012, 01:35 PM   #704
Backbones is offline Backbones  United Kingdom
Any chance of a photo of your heatsink arrangement buzzforb?
Old 5th March 2012, 01:56 PM   #705
buzzforb's Avatar
Not worthy of storage space. Mine actually get hot. The jfets are part of the control mechanism and may be the problem that'd why I asked yap about current through their source resistors.
Old 5th March 2012, 06:06 PM   #706
Botte is offline Botte  United States
Botte's Avatar
The DC offset drift in my follower stage is minimal, less than +-.005mV.
The FE drifts all over the place that's why it's capacitivly coupled to the follower. Any DC on the input would exacerbate this drift.
Old 5th March 2012, 07:19 PM   #707
buzzforb's Avatar
Nelson does mention that in the article.
Old 5th March 2012, 11:09 PM   #708
Yap BC is offline Yap BC
If I don't understand wrongly, the FE's dc offset should be tuned without hooking up with the preamp and source. The main problem is that when I hooked it with the preamp, the FE's dc offsets will drift away by as much as 160mV on the right channel and about 40mV on the left channel (immediately). That really puzzled me. The dc on the input (DCB1 for my case) is rock solid at 3.5mV on the right and 0.1mV on the left.
Old 5th March 2012, 11:45 PM   #709
buzzforb's Avatar
By adding just a little bit of DC to the FE of the BA3, you are basically affecting its bias. Normally the gate would be pulled to ground and the bias would be fully open if not for Rs, which create a positive voltage and dynamically reduce the current through the fet. with even a small DC at the gate, you change the bias point, and as a result everything that depends on that throughout the rest of the chain. Hopefully someone will confirm or shoot down this explanation and make it clearer.
Old 6th March 2012, 02:31 AM   #710
I am no expert in electronics and hope you won't mind my stupid question here. Will a dc component be amplified also if it is present together in a signal? If it does, then it is more logical to explain that the dc component is amplified to 170mV at the FE stage from DCB1's dc offset of 3.5mV although the amplification factor is about 48 times.
The Idss for the Jfets is 9.1mA. Currents on the Jfets are 7.79mA and 7.74mA measured at R6 and R7 respectively on the right channel with the top cover fixed up. Without the top cover, its 7.62mA and 7.57mA.
I had measured them with the power amp hooked up and unhooked up with the DCB1 with both situations showing almost the same readings, only a slight difference of 0.01mA
I can't measure the temperature as I do not have a thermometer with me now. I guess its about 60 ~ 65 degree Celcius or 140 ~ 149 degree Fahrenheit.
Burning Amp BA-3Hide this!Advertise here!
Burning Amplifier BA-1 Variac Pass Labs 356 17th January 2017 11:54 PM
Burning Amplifier BA-3 Nelson Pass diyAudio.com Articles 39 14th October 2016 11:36 AM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
