Burning Amp BA-3 - Page 68 - diyAudio
Old 17th February 2012, 10:18 AM   #671
As a matter of interest, how many of us are using some form of regulator for any of the BA-2, BA-3 front ends?
Old 17th February 2012, 04:56 PM   #672
Botte is offline Botte  United States
Botte's Avatar
I'm using a shunt reg on my BA-3FE +-29 volts
Old 18th February 2012, 12:03 AM   #673
eyoung is offline eyoung  United States
eyoung's Avatar
Who is keeping up on the F5 turbo thread (diodes across resistor debate)same result ...more voltage swing.
Regards, E
"Lead me not into temptation...I can find it myself."
Old 18th February 2012, 08:08 AM   #674
bobodioulasso's Avatar
Diodes are interesting when low impedance loads are used as they increase considerably the available current. Though, in that case, it's not the voltage that counts.
Using 8 ohm load, little voltage is gained as long as voltage drop across source resistors is not that high.
Old 21st February 2012, 07:12 AM   #675
ENSen is offline ENSen  Sweden
I have a BA-2 and was thinking of trying the BA-3. I have separated the PCBs for left and right FE for my BA-2 and I would like to do the same for BA-3 to be able mount them in the same place using the same wiring. When I checked the pictures of the BA-3 boards in the diyaudio shop I noticed that they do not have mounting holes in the middle. So if I separate the left and right FE I will only have mounting holes in one end of them. Is this done by purpose? Is there a reason why one should not separate left and right PCBs?
Old 21st February 2012, 07:28 AM   #676
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
It just got too difficult for Papa to fit everything in and we didn't think many people were cutting them.. .. As far as I know, there is no reason not to cut them. Using 2 holes on the side of each piece is probably enough. and there's a line to help guide your Dremal tool!
Which of the corner holes are you using? the ones in the extreme corners or the ones inboard a bit?
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio [/B]
Old 21st February 2012, 07:35 AM   #677
Thank you for the quick answer Variac. I am using the holes in the extreme corners but maybe I should use the other holes for the BA-3 to get a little better force distribution?
Old 21st February 2012, 08:54 AM   #678
diyAudio Editor
Variac's Avatar
I think either way will be fine, but I guess the inner holes would be stronger.
But bolting them right in is pretty appealing, right?
Old 21st February 2012, 08:56 AM   #679
Yes, it is appealing but it's not that bad to drill a few new holes.
Old 21st February 2012, 10:55 AM   #680
Darry is offline Darry  France
The output stage of BA1 works in pure single-ended.
With 0.58 A per MOSFET (6), the BA1 provides, with ± 32V, 50 watts into 8 ohms, 25 watts into 4 ohms but only 12 of 2 ohms, ...
Is there a "small" circuit that could push the output stage in class AB (in the style of the Aleph 0, 0s and 1), for at least 50 watts into 4 ohms and 2.
Darry
Burning Amplifier BA-1 Variac Pass Labs 356 17th January 2017 11:54 PM
Burning Amplifier BA-3 Nelson Pass diyAudio.com Articles 39 14th October 2016 11:36 AM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
Copyright ©1999-2017 diyAudio
