That is correct. On most fets, not sure about all, the drain pin is electrically connected to exposed metal on the back of the fet. William is right about the D+ voltage. If the bias boards are working, then set it to zero or any number 3V and below. I said 3V because for the IRF, this should be below their turn on voltage. Zero is safer. If you fet are ok, then you now only need to watch the Vdrop across the source resistors of the fets and offset between output and ground. When turning up the bias, a quick way to make sure the fets are sharing current evenly is to check the Vdrop across each fets Rs on the top and bottom. They shoud be close to the same. Check it at a low bias of .050V across the Rs. This is a low enough current that if you have some issues, you still should be safe from cooking other fets.
hi zen,
hi Zen,
The scopes rated to 150mhz, I payed dearly for it 30 years ago and it still works fine,lol.It was made by KENWOOD and I can make it big enough for a oldman like me to see,lol.
So if I put some small caps on the end of the big uns it should decease ,and yes could be stray caps there,it's not in a chassis yet ......
Thanks,
NS
you have a good scope , and eyes too , if you can observe mHz
put some bypass caps on final biguns , even if that's certainly filth from environment , not PSU itself
hi Zen,
Thanks,
NS
Andrew,
Out of curiosity, on another thread you were talking about segmenting micas into thinner layers -difficult to comprehend based on this experience. How did you install those, and were you using something wider than TO-220?
This morning I swapped the front end leads to confirm the channel volume imbalance is coming from it and not the bias or output boards. What adjustments/readings are needed to get that resolved?
Easiest way is scope and dedicated signal. ITs unlikely that it is bias boards if all measurements are comparable there. Take time and go through both channels of bias/output boards. Right down the key voltages on paper and compare. Lets eliminate any possibility there. Sounds more like a FE thing, but no reason not to be thorough. Main points of concern on output boards are Rs vlues of each fet. For kicks, measure the D+ and D- values to see if they are close/similar.
Understood - that will take a while, but I'll put all the readings together on a photo/diagram. Be back soon.....
I don't own a scope, but if I can get an audio interface for my iPad from Staples today - there are a couple apps that might get me in the ballpark. (I needed an excuse to do that )
- Burning Amp BA-3
