Burning Amp BA-3 - Page 50 - diyAudio
Old 28th November 2011, 12:54 AM   #491
timbarnes's Avatar
Default Biasing
Originally Posted by JimM View Post
Ok got it, my simulation has Idss of 10ma, I was biasing 2sj and 2sk way to high so good lesson to ensure P1 and P2 start at zero ohms and turn to get the 1.0volt drop across R10 and R11, unless you want a burning amp. In simulation with IDSS of 10ma pots were set at around 250 ohms.
I'm biasing mine at 1.1V across R10 and R11 (higher quiescent current helps with a slightly too-high power supply voltage). The heatsinks get faintly warm.
I had to add 330 ohm resistors on the back of the board to get past 0.85V on one side as well.
I also added 10uF capacitors across the power supply in the BA-3 box as per Nelson's latest schematics. Result of these changes is a smoother sound that appears a touch rolled off in the treble until I play something like harpsichord or percussion, when it becomes obvious that there's plenty of treble when needed.
Townshend Rock III, Hagerman Bugle 2, Naim CD5i, RPi Volumio, MiniDSP, Elliot P101, IRS2092, Parham Pi Sevens & Pi Three
RC Preamp (in progress), Pass BA-3 and F4, DIY Silver cables, Open Baffle BOFU, DIY subwoofer, GainClone, o2 Headphone Amp
Old 28th November 2011, 01:32 AM   #492
Variac is online now Variac  Costa Rica
diyAudio Editor
Variac's Avatar
EDITOR'S NOTE:
ALL info on the BA-3b, the Balanced BA-3, are moved here:
Burning Amp BA-3b (Balanced)
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio [/B]
Old 28th November 2011, 01:36 PM   #493
What DC offset is acceptable for the BA-3 anyone? I have 4mV at present.
Old 28th November 2011, 01:44 PM   #494
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
where ?
on output of FE or on output stage itself ?
in both cases - more than good
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 28th November 2011, 01:48 PM   #495
Originally Posted by Zen Mod View Post
where ?
4mV across the 330ohm resistor of the output of the BA-3.
Old 28th November 2011, 02:30 PM   #496
Zen Mod's Avatar
good .
Old 28th November 2011, 03:22 PM   #497
generg is offline generg  Germany
generg's Avatar
congratulation....... ! your J-Fets now seem to work......
and the First Wtt is......a really First Class PSS Idea
Old 29th November 2011, 09:44 AM   #498
Thanks to you.
I let the amp run for about 45 minutes, during which the DC offset swung between +60mV and -100mV until with a few adjustments it settled between -6mV and +6mV. R10 and R11 settled in at about 1.07V and R3 and R4 were both 0.058V with P3 set dead centre.
I plugged this unit (this is the left channel monoblock) into the system last night and I'm running it again this morning. Quite distinct from the BA-2 on the right channel but comparisons are not easy because the left BA-3 is powered by the Salas voltage regulator and the right one is not (not yet anyway). On first listening the slight chestiness to voices on the BA2 has been replaced by a more even and open sound. Percussion on cymbals is more distinct in the sense I can hear a clearer sense of impact and decay and a clearer sense of position. Instruments are easier to separate from the mix. However, some of this will be the upgraded voltage reg I am sure. I am certainly getting more detail from the amp at lower output levels than I was whilst there is no sense of hardness to the sound (not that there was any on the BA2).
Old 29th November 2011, 11:19 AM   #499
generg's Avatar
I could write very similar words, thanks for impression......
"more open, more distinct, sense of position, easier to separate, more detail on lower output level, no sense of hardness"
what do we want more......
till the next project.....
Old 29th November 2011, 11:53 AM   #500
I think we need to let those who are building for the first time that the BA2 is an outstanding amp in its own right. I hadn't heard anything as good as the BA2 even after years spent auditioning some very expensive amps and there will be those who prefer the BA2 sound. For those building for the first time I would go for the BA2 because I found the front end easier to build and set up. I have had a lot more problems with the BA3 and I think I might have given up had it been my first build.
Of course I wouldn't have given up; you guys would have sorted it out.
Burning Amplifier BA-1 Variac Pass Labs 356 17th January 2017 11:54 PM
Burning Amplifier BA-3 Nelson Pass diyAudio.com Articles 39 14th October 2016 11:36 AM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
Copyright ©1999-2017 diyAudio
