Burning Amp BA-3
Burning Amp BA-3
Old 21st November 2011, 05:57 AM   #441
h_a is offline h_a  Europe
h_a's Avatar
@kenpeter: why an IRF610 in the tail? Try something like the 2SK246, nice long channel jfet for CCS applications. See also for Walt Jung for a more detailed discussion on current sources!
Home
Hannes
High Octane phono preamp Wiki
Old 22nd November 2011, 03:01 AM   #442
Rembulan is offline Rembulan  Indonesia
Rembulan's Avatar
Send a message via Yahoo to Rembulan
I really like to try this BA-3 amp in my system but after looking for 2SJ74 in my local market ( Indonesia) I give up.
my question is can I use IRF9610 and IRF610 with this configuration ?
and before I burn my finger because to much current in my 9610 can somebody help me what I should do.
Thank You
Old 22nd November 2011, 03:14 AM   #443
kenpeter is offline kenpeter  United States
So JFET quiescent drain Voltages and channel currents are forced same.
One drain already driving an IRF610 in the output stage, now both do...
Pretty much eliminates the need to trim for equal current in both legs.
The middle leg dumps any mismatch, as it shunt regulates tail current,
and doubles the open loop gain.
Old 22nd November 2011, 06:18 AM   #444
generg is offline generg  Germany
generg's Avatar
Burning Amp BA-3
Thank You
Try this, still working.....
Store
and the First Wtt is......a really First Class PSS Idea
Old 22nd November 2011, 06:34 AM   #445
AudioSan is offline AudioSan  Norway
+1. just got my matched sj74/sk170 yesterday. good price and fast delivery.
Old 22nd November 2011, 07:18 AM   #446
h_a's Avatar
I was missing the connection to the drain last time.
With respect to THD, D. Self nicely showed that one needs well balanced DC-currents in the differential pair, so I assume you refer to DC-balance.
If so, your shunt reg should work only at DC, which it clearly does not. It also acts at AC, which is an entirely different story as the tail current becomes modulated.
AC tail current modulation does not appear to me to bring straightforwardly only positive improvements, so I would be curious about your arguments.
Also, I don't see why this shunt shall double OLG of the input stage as it is not an active load with almost infinite impedance like a current mirror.
Hannes
Old 22nd November 2011, 02:11 PM   #447
Rembulan's Avatar
Store
Thank You for your suggestion, can not buy from overseas its cost to much.
Old 22nd November 2011, 02:42 PM   #448
Backbones is offline Backbones  United Kingdom
Can't get 1V across R10 or R11.
P1 and P2 are 500ohm. Max resistance creates 0.5V on R10 and 0.1V on R11.
Have tried adding 470ohm to P1 and P2 and this makes no difference although I'm not sure I've broken the trace fully.
Just checking that Q3=2SJ313 and Q4=2SK2013.
Any thoughts?
Chris
Old 22nd November 2011, 02:54 PM   #449
generg's Avatar
Burning Amp BA-3
I can send you these two pairs matched by a friend with a curve tracer......
PM me please
Old 22nd November 2011, 03:01 PM   #450
generg's Avatar
Burning Amp BA-3
Q3, Q4 seems correct to me, is he polarity of the caps correct?
Burning Amp BA-3Hide this!Advertise here!
Burning Amplifier BA-1 Variac Pass Labs 356 17th January 2017 11:54 PM
Burning Amplifier BA-3 Nelson Pass diyAudio.com Articles 39 14th October 2016 11:36 AM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
