Burning Amp BA-3
Burning Amp BA-3
Old 13th November 2011, 08:46 PM   #431
Backbones is offline Backbones  United Kingdom
Originally Posted by tinitus View Post
Salas reg sounds interesting
I could 'steal' the reg/supply section from a couple of boards I have from symmetric B1 project GB
have thought about it, but I don't know if its suited fore this voltage
remember someone having pretty hot mosfets
and my trafo is 2x22Vac
maybe good heatsinks will do the trick
Check out the 'SSLV1.1 builds and fairytales' thread but I have now modified the reg and the mosfet are now running pleasantly warm and not terminally hot as before. The problem was that I was not balancing the input current and output current. The excess input current was resulting in excessive heat.
I'll keep you posted.
Chris
Old 15th November 2011, 11:06 PM   #432
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Burning Amp BA-3
hey,
its OT, and fore other purpos so I hope a short answer will do
will it be ok to raise input to ground resisitor to about 1M ohm or so, to achieve high Z input ?
Old 16th November 2011, 12:14 AM   #433
buzzforb is offline buzzforb  United States
buzzforb's Avatar
The question will be whether that interacts poorly with any leakage current from fets. I wouldn't think so. Also, don't higher value resistors introduce more noise relative to their lower rated counterparts? Just guessing though.
Old 16th November 2011, 01:45 AM   #434
Burning Amp BA-3
yes
just got this crazy thought I would test it on my bass guitar
Old 16th November 2011, 07:18 AM   #435
triode_al is offline triode_al  Netherlands
triode_al's Avatar
the source [I mean where the signal comes from - preamp] will also have a resistor, and that often is not more than 100k.
they are in parallel.
SPU --> tube MM/RIAA;
Pass buffer -->300B SE Anzai Zaïka (WE91 & 6SJ7); --> FE120 TQWT
Old 16th November 2011, 11:39 AM   #436
Burning Amp BA-3
well, it is a bit quiet, so....
I was thinking of plugging bass guitar jack directly into BA3 FE
if a stereo module, maybe I could cascade them(series), with master control between
Old 19th November 2011, 05:51 AM   #437
kenpeter is offline kenpeter  United States
Before I realized BA2 front end was already obsoleted by BA3,
I had thrown a few of my zany ideas at the older topology...
Shunt regulated tail, etc etc...
Old 21st November 2011, 12:27 AM   #438
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Burning Amp BA-3
Originally Posted by kenpeter View Post
Before I realized BA2 front end was already obsoleted by BA3...
Nothing is obsolete. Just different.
Old 21st November 2011, 01:14 AM   #439
buzzforb's Avatar
ZM, You know where to get some Icar caps on this side of the pond? Or perhaps a known equivalent. considering this as last cap before BA output stage. I will have 54000 uF with seperate PSU case, another 24000uF power amp case. Haven't considerd whether there is anything to having the same amount in on each C leg of CRC
Old 21st November 2011, 01:20 AM   #440
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Burning Amp BA-3
just use any proper motor runs
last time I checked ( somewhere in first decade of making Klipsch Horns ) GE were decent .....
dunno - maybe just try to avoid cheapest ones
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Burning Amp BA-3Hide this!Advertise here!
Burning Amplifier BA-1 Variac Pass Labs 356 18th January 2017 12:54 AM
Burning Amplifier BA-3 Nelson Pass diyAudio.com Articles 39 14th October 2016 12:36 PM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 03:53 AM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 04:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 03:35 AM
Copyright ©1999-2017 diyAudio
