Burning Amp BA-3 - Page 35 - diyAudio
Old 30th October 2011, 12:10 AM   #341
JimM is offline JimM  United States
Toshiba parts?
Old 30th October 2011, 12:18 AM   #342
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
5 bucks a pair for 50 cent parts would be amusing.
(but how does it sound with J77/K214)
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 30th October 2011, 12:49 AM   #343
buzzforb's Avatar
Could you tell me where to get them for .50$ as i would like to get some more. Yes JimM, I have matched Toshiba 2SK2013/2sj313 from a group buy that did not pan out.
Old 30th October 2011, 01:03 PM   #344
buzzforb's Avatar
I have a question regarding the implementation of the BA-3/B and BA-2 FE's as modules. In passing the signal from a standalone unit containing the FE, does the signal wire need to be grounded. I realized as I was putting the two FE's in their seperate enclosures, that the BA-3 only had a single signal output, whereas the BA-2 has a signal output plus the requirement for a feedback signal. If it is necessary to ground this output, then i will have to use an RCA for BA-3 and XLR for BA-2. I know that in the same amp, this requirement for grounding does not exist, but was unsure if passing the signal from one case to another required it. I have a umbilical chord made of 4 pin Speakon connectors bringing earth and signal ground as well as associated DC connections from output stage and PSU.
Old 30th October 2011, 01:58 PM   #345
generg is offline generg  Germany
generg's Avatar
I had a little difficulties to understand your words... German....ha, ha
but I think you see the matter correct
grounding is necessary for both BA-3 and old frontend and the old frontend also needs the feedback cable......
Gerd
and the First Wtt is......a really First Class PSS Idea
Old 30th October 2011, 03:35 PM   #346
Originally Posted by buzzforb View Post
.50$
Referred to the Fairchilds.
($5 for J313/K2013 is expensive, they do $4.5/pair in Japan )
Old 30th October 2011, 09:49 PM   #347
I have been mulling over this same problem. I think you need to take the ground from the BA-3 via an interconnect to the star ground of the power supply of the power board. My problem with this is that you will need another high quality interconnect ie, one from the pre-amp to your BA-3 and then another from the BA-3 to the power side. I think this arrangement is more likely to cause signal problems (interference) than using an external power supply feeding your BA-3 inside the power output chassis. I am favouring the latter idea now.
Chris
Old 30th October 2011, 09:54 PM   #348
Originally Posted by generg View Post
But I learn ... Do you have to wait a long time for your replacements?
Should know tomorrow if I can get hold of the mosfets. However, I have been making good use of my time by putting together a Salas regulated power supply for the BA-3 (or the BA-2 if I wish).
Chris
Old 30th October 2011, 10:10 PM   #349
buzzforb's Avatar
Chris
IF done properly, I don't see why it would be any different than a usual preamp/amp setup. If I like what i hear, I will probably go to a passive volume control as the BA-3 will become the new "preamp". The reason I like the idea is ease of construction on FE options. If you can run it off the PSU of the output stage, you drop building complexity and interchangeability becomes simple. Connections can be as short as 1-1/2' feet.
Old 30th October 2011, 10:53 PM   #350
rsdio is offline rsdio  United States
If you're concerned about grounding issues, then you really should just stick to XLR balanced signal interconnects. I would not recommend speakON for line level signals, but rather restrict that connector to power and speaker interconnects.
RCA was designed as an interconnect within a single chassis. The unfortunate fact that it was abused to link multiple chassis is a mistake of the consumer market. If you use XLR balanced instead, then these grounding issues that you describe fall out (provided that you properly wire your XLR outputs and inputs).
Unfortunately, I don't know what to suggest for the preamps and amplifiers that do not support balanced I/O. Personally, I am limiting my DIY experiments to balanced, so that means skipping the unbalanced designs or modifying them for balanced. There are plenty of balanced designs from Nelson Pass to keep me busy, so I'm not fretting over the limitations.
Burning Amplifier BA-1 Variac Pass Labs 356 17th January 2017 11:54 PM
Burning Amplifier BA-3 Nelson Pass diyAudio.com Articles 39 14th October 2016 11:36 AM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
Copyright ©1999-2017 diyAudio
