Burning Amp BA-3
Burning Amp BA-3
Old 5th August 2015, 04:54 PM   #2031
Rothor is offline Rothor  Sweden
Couldn't arrange to have the Bonnecs picked up in time, so I missed that opportunity... =(
Old 5th August 2015, 08:21 PM   #2032
Danger Mouse is offline Danger Mouse  Germany
Danger Mouse's Avatar
Originally Posted by wengtech View Post
hello again,
i have 4pcs Rcore single 32vac 180va each.
(that will be 2x32vac 360va for one channel)
if i separate the supply for gain stages.
is it okay to supply for the output stages?
thanks.
why not try the cascode from F5 Turbo V3 this cascode should also work for the BA3 frontend
So you could easyly use the transformers
Or i`m wrong?
Old 6th August 2015, 02:06 AM   #2033
wengtech is offline wengtech
Hi Danger Mouse,
Yes that is one solution using cascoded for a higher voltage rails.
But since the jfets k170 j74 very likes a low voltage, I think I have to make separate PSU for the gains rails.
And keep the voltage as low as possible without the help of cascode transistors.
Also, cascode and without cascode will "sound" quite different, and I like without.
18-20v is sweet enough for the jfets.
Old 6th August 2015, 03:09 AM   #2034
Russellc is offline Russellc  United States
Burning Amp BA-3
Hi Danger Mouse,
I'm finding 31 volt rails pretty darn sweet. Of course mine is complementary, not single ended.
Taken from 6L6's build thread:
Complimentary output, 24V rails - 25WPC, 8ohm. More into 4ohm
Complimentary output, 32V rails - 40WPC, 8ohm. More into 4ohm.
Single-ended output, 24V rails - 25WPC, 8ohm. Less into 4ohm.
I guess you can go higher rails with single ended?
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre Tekton Enzo, Altec A7, Econowave JBL 2235H & B&C CD
Old 6th August 2015, 01:51 PM   #2035
stormfrontier is offline stormfrontier  United States
stormfrontier's Avatar
Quick question: The single-ended bias boards only have P1, so I'm assuming that there is no "offset," and that the only thing that needs to be set for the outputs is the bias itself?
Also, the FE gets biased to 1V, or a little under. Do the output boards get biased to the same amount?
Old 6th August 2015, 03:03 PM   #2036
coils is offline coils  United States
Hi storm, I built the se version, the pot on the bias board zeroes the dc offset on the output terminals, the bias is fixed.
Coiler
Old 6th August 2015, 03:13 PM   #2037
Do you remember what the bias is fixed at for the outputs?
Old 6th August 2015, 03:24 PM   #2038
Burning Amp BA-3
I dont know if this helps, but with my complimentary BA-3, while the FE board biased like you say, from .900's to 1.000, the output stage, depending on room, circulation and so forth in a 5U chassis was limited to .46 or .50. Maybe this winter ( or with a babysitter ) a little higher. At this level the heatsink was reaching 52 degress centigrade.
Perhaps if someone with an up and running would measure across one of the resistors on the output board they could tell you, but if it is fixed, I guess it is fixed. I dont remember the BA-3 article mentioning it, but it may have escaped me as I was going complementary.
Anyone out there running a single ended BA-3 that wouldn't mind measuring this for stormfrontier?
Russellc
Old 6th August 2015, 06:34 PM   #2039
I built it per spec with +- 25 volt rails, and 1 ohm source resistors. Bias is .58 amps per quasi comp pair. I have 6 pairs for 3.5 amps bias. I only use the se outputs and bias boards, I don't use the front end.
Coiler
Old 6th August 2015, 10:01 PM   #2040
You can decrease the bias with the addition of R219 on the bias board. My final build does not use it.
Coiler
Burning Amp BA-3Hide this!Advertise here!
Burning Amplifier BA-1 Variac Pass Labs 356 17th January 2017 11:54 PM
Burning Amplifier BA-3 Nelson Pass diyAudio.com Articles 39 14th October 2016 11:36 AM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
