Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Pass Labs This forum is dedicated to Pass Labs discussion. |
#1611 |
Thanks Evan. Need any aluminum dust ??
Bob M. "Arrange Whatever Pieces Come Your Way." |
#1612 | |
#1613 |
This build has been running without a C9 cap (ghosted blue). Instead of just asking where to place it (them), I drew out the circuit so any additional suggestion could be added. The CL-60s run very hot which I believe is normal, but not sure they are in the best location.
So how many C9s and where? ![]()
Bob M. "Arrange Whatever Pieces Come Your Way." Last edited by bcmbob; 3rd April 2014 at 03:51 PM. |
#1614 |
Official Court Jester
NTC needs to be hot , to drop resistance
greenhorn alert !: pull off mains cord!! , then touch NTC ! that way you'll burn just finger , not brain ![]()
my Papa is smarter than your Nelson ! clean ![]() ![]() ![]() |
#1615 |
R.I.P.
Fitting bypass relay contacts will get the temperatures down.
And prepare the NTCs for the next occasion they are required.
regards Andrew T. |
#1616 |
My fingers are just fine - thank you! As for the brain part, remember I lived through the "60s" so I'm working mostly with cinders there.
![]() My thought was the CL-60s should cool somewhat after the resistance falls, but they stay right up there. I won't fret about it. Andrew - your idea sounds slick, but I believe would require an additional power source - correct? No mention of the C9 filtering. Does that imply it may be considered optional and required on noisy mains only? I see there are two in the BA-1 PS schematic: "Capacitors C1 and C2 are line-rated types only, as they will be filtering AC line voltages."
Bob M. "Arrange Whatever Pieces Come Your Way." Last edited by bcmbob; 3rd April 2014 at 07:49 PM. |
#1617 |
Not if you use an AC relay. Look at the attached soft-start circuits.
#1618 |
#1619 |
Some clever ideas. I'll take a shot at incorporating something similar in the upcoming complementary (& hopefully balanced) build.
#1620 |
How about a BA-3 3-deep Turbo? With 32V rails and 1A bias per device what would we get for output power? Would the big chassis heat sinks be big enough? Would I need a fire extinguisher? What would it take to get to 50 watts?
Thread | Thread Starter | Forum | Replies | Last Post |
Burning Amplifier BA-1 | Variac | Pass Labs | 356 | 17th January 2017 11:54 PM |
Burning Amplifier BA-3 | Nelson Pass | diyAudio.com Articles | 39 | 14th October 2016 11:36 AM |
Burning Amplifier BA-1 | Nelson Pass | diyAudio.com Articles | 3 | 24th October 2011 02:53 AM |
WTB: Burning Amp BA-1 or BA-2 | jdubs | Swap Meet | 0 | 23rd March 2011 03:16 AM |
FS: two burning amps (one each BA-1 and BA-2) without drivers | Eric Weitzman | Swap Meet | 15 | 17th February 2010 02:35 AM |
New To Site? | Need Help? |
