Burning Amp BA-3 - Page 142 - diyAudio
Old 9th October 2013, 02:57 PM   #1411
6L6 is offline 6L6  United States
6L6's Avatar
If you can get them dialed in with single turn pots, there is no need to use anything else.
Nelson used single-turn in the original, so if it's good enough for him...
Old 9th October 2013, 03:00 PM   #1412
bcmbob is offline bcmbob  United States
Good deal - thanks.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 10th October 2013, 08:17 AM   #1413
Originally Posted by Neville View Post
................................Have not messed with P3 yet, still set at zero.... oh and yes this time I did check all pots for min value before firing it up......................
Should P3 be set to middle of range, or to zero ohms?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 10th October 2013, 03:17 PM   #1414
Neville is offline Neville  United States
It should be set to middle of range. I just set it to zero for now but will dial it to 50 ohms, BOM asks for 100 ohms pot.
Just to make sure I was not throwing my jfets away, I put them back in and alas they were fried.....one channel completely dead and the other was very low and distorted.
Put back the jfets I had in and music. Very expensive noob mistake !!!!!! still kicking myself for this.
Loving the combo BA-3 and F4...As Backbones said.....marmite changer (ugh..hated that stuff, give me jam any day.), if I compare to my F5
Old 11th October 2013, 02:20 PM   #1415
jarkaa is offline jarkaa  Finland
Default Cascoded hv version
Hello,
I searhced for HV voltage version of BA-3. Could not find any so I decided to draw a schematic.
My aim is to drive class AB follower to with this.
I have tried many front ends before and I would like to try also this.
The rail voltage will be somewhere between +/-42V-55V
Any impressions on the design?
Last edited by jarkaa; 11th October 2013 at 02:24 PM. Reason: Forgot to add the rail voltage
Old 11th October 2013, 10:02 PM   #1416
Your voltages are too high I'm pretty sure. Do read Nelson's build notes. It really doesn't take any time at all.
Old 11th October 2013, 10:29 PM   #1417
gl is offline gl  United States
Generally speaking your circuit should work. I've built a similar version that ran fine at 36V.
However, you will need to recalculate the power ratings on a number of the resistors.
The cascode transistors Q3 and Q7 are also too small. I would suggest the 2SA/2SC parts used in the F5 Turbo. That's what I used.
Graeme
Old 30th October 2013, 04:29 AM   #1418
mstomaso's Avatar
Default Need Help With BA-3 Front End Problem
I am building a push-pull BA-3. The output stage is working like a champ. The input stage is another story.
As soon as I apply power, R11 on both sides of the board smokes. I am using FQ3P20s and 1K pots. I have changed out both Q4 power FETs thinking they were bad and the same thing happened a second time. I have set P2 to zero ohms (full CCW) at start-up.
I get about 1.5 to 1.6 ohms across R10 on both sides with P1 set to zero ohms (full CCW).
I'm clearly doing something dumb but I don't know what it is.
Any thoughts?
Old 30th October 2013, 07:57 AM   #1419
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
are you building them on store pcbs or at backyard ?
pics will help
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 30th October 2013, 12:25 PM   #1420
mstomaso's Avatar
Building them with store PCBs. :-)
My post had an error - it's 1.5-1.6V across R10, not ohms. It was a long night.....
Burning Amplifier BA-1 Variac Pass Labs 356 17th January 2017 11:54 PM
Burning Amplifier BA-3 Nelson Pass diyAudio.com Articles 39 14th October 2016 11:36 AM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
Copyright ©1999-2017 diyAudio
