Burning Amp BA-3 - Page 138 - diyAudio
Old 21st September 2013, 04:22 PM   #1371
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
MODU in Italy
Do you have a link to Italy?
Regards Åke
Old 21st September 2013, 04:26 PM   #1372
modu
Old 21st September 2013, 09:07 PM   #1373
bcmbob is offline bcmbob  United States
Originally Posted by Backbones View Post
I upped the bias on the power boards to 400mV today.......
Can you confirm that the process was simply reducing the size of the resistors, and what value did you use? Any other adjustments needed?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 21st September 2013, 09:48 PM   #1374
Itsmee is offline Itsmee  England
Itsmee's Avatar
I upped the bias on the power boards to 400mV today.... ....They sound great....
Your defiantly a member of the FAB club
Old 22nd September 2013, 06:29 PM   #1375
They produce the chassis for the diyaudio store but if you are in Europe best to order direct from them. However, good idea to use the specs provided by the diyaudio store when ordering because you will then get the heatsinks drilled and tapped for the mosfets on the power board and the back plate ready for speaker posts and mains sockets etc. Also the base plate in the amp chassis that I got doesn't align with the holes in the pcb modules but they now have one that addresses this issue. None of these things is that important it just means you spend a bit longer away from your nearest and dearest. Can be good can be bad!
Old 22nd September 2013, 06:37 PM   #1376
I couldn't explain it better than Nelson does in his build instructions.
Old 26th September 2013, 11:26 AM   #1377
Thanks, Just wanted to make sure I wasn't missing any secret tips and tricks.
Bob M.
Old 27th September 2013, 10:34 PM   #1378
This paragraph in the B-1 Buffer article caught my eye:
"At the moment I’m driving a pair of Lowther DX55’s with some passive baffle-step correction (6 dB loss there) and an F3 amp with only 12.5 dB voltage gain. The preamp is fed by an Xono phono stage with a low output cartridge (Grado Statement).
The sound is extremely neutral without being clinical - just about what you were looking for when you were thinking about a passive preamp. A teensy bit of second harmonic and no noise at all.
There’s just enough gain. If you were using any other power amp, you’d get 8 to 18 dB more gain, and would be able to break your lease or the speaker, or both
The 8 to 18 db more gain is what I'm curious about. Anyone want to take a guess, or provide a formula that can predict how that would translate to the BA-3 when compared to the F3 Mr. Pass was using ?
Bob M.
Old 28th September 2013, 12:26 AM   #1379
just another
wintermute's Avatar
I think what he is saying is that 12.5db is a very low voltage gain and a typical amp will have 20 - 30db of voltage gain.
The B1 is a buffer so what comes in is what comes out (voltage wise) so with a low gain amp (perhaps designed to work with a preamp with gain) you might not get enough volume to shake the rafters.
As the BA3 has 30db of gain by default it should be absolutely fine with a B1. As I posted earlier I'm looking at dropping it to 20db which I think should be adequate and I will effectively be using a B1 with it. I say effectively because there will also be active filters in the circuit.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 28th September 2013, 10:18 AM   #1380
One could read that paragraph and get the impression there could be a multiplier effect dependent on amp selection/combination - at least I did, which didn't sound like a buffer. Thanks for clearing that up.
Bob M.
Burning Amplifier BA-1 Variac Pass Labs 356 17th January 2017 11:54 PM
Burning Amplifier BA-3 Nelson Pass diyAudio.com Articles 39 14th October 2016 11:36 AM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
Copyright ©1999-2017 diyAudio
