Burning Amp BA-3 - Page 132 - diyAudio
Old 7th September 2013, 08:01 PM   #1311
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
loose windings, or ?
sometimes we know very little, and sometimes we know too much
Old 7th September 2013, 08:35 PM   #1312
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
most probably
whatever it is - it's flawed
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 8th September 2013, 02:25 AM   #1313
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
hopefully their warranty department isn't flawed....
http://www.evancotler.com
Old 8th September 2013, 11:42 AM   #1314
Here are some photos:
Old 8th September 2013, 12:19 PM   #1315
bcmbob is offline bcmbob  United States
Quiz Time
Your power supplies appear more complex than the Pass units. Can you give some details?
What are the large brown caps and why did you select them?
Are you using one bridge rectifier for both tranis? Just can't see a second.
Can't quite see where the speaker grounds are connected.
Yea, I'm nosy , but that's a nice clean set to gather some good ideas.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 8th September 2013, 12:31 PM   #1316
6L6 is offline 6L6  United States
6L6's Avatar
A quiz! Fun!
Elna Silmic
The bridges are discrete, on the PSU PCB, under clip-on heatsinks. The bridge on the back panel is a ground-breaker.
Back at the PSU
Backbones - a fantastic build! Thanks for sharing!
Old 8th September 2013, 12:39 PM   #1317
You can go to the head of the class . Spelling bee is next ----
Bob M.
Old 8th September 2013, 12:42 PM   #1318
I'm a bit nosy myself when it comes to other people's designs.
Power supplies are same as Nelson's design. I use boards from Avondale Audio over here in the UK. There is one each side. I have soldered a bank of 4 Schottky diodes (fitted with heatsinks) at one end which then feed into Nelson's CRC arrangement with a final 10uF 250V output cap made by Clarity. This gives the split rail supply so only one set of rectifying diodes per channel. The rest of the caps are 10,000uF Mundorfs. If you want the boards from Avondale unpopulated as I did you will have to phone them and in fact they may not do this size anymore but it is worth asking. They are mounted on the back of the front plate.
The large brown caps I think you are referring to are the 1000uF Elna Silmic II on the front ends. They don't quite fit the boards but they sound very good. They have an element of relaxed analogue about them without any loss of detail. Not sharp or brittle.
Speaker grounds are taken from the central pin on the power supply output boards (they are the white ones) and they pass to the upper speaker post. The other white ground is attached to the same output pin of the power supply and passes to the front end ground.
The central ground of the power supply is also connected to the earth ground via a CL60.
Old 8th September 2013, 12:47 PM   #1319
Originally Posted by 6L6 View Post
A quiz! Fun!
Elna Silmic CORRECT
The bridges are discrete, on the PSU PCB, under clip-on heatsinks. CORRECT
The bridge on the back panel is a ground-breaker. NO BRIDGE SORRY THAT IS WRONG
Back at the PSU
Itsa Pleasure
Old 8th September 2013, 12:49 PM   #1320
Very nice. I've auditioned various caps on several MyRef builds but haven't seen a lot of discussion in that area on the Pass threads. Something to look forward to down the road.
TNK.
Bob M.
Burning Amplifier BA-1 Variac Pass Labs 356 17th January 2017 11:54 PM
Burning Amplifier BA-3 Nelson Pass diyAudio.com Articles 39 14th October 2016 11:36 AM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
Copyright ©1999-2017 diyAudio
