Burning Amp BA-3
Burning Amp BA-3
Old 10th August 2013, 08:15 PM   #1231
bcmbob is offline bcmbob  United States
Thanks William, but after Googleing a bit, and even with your diagram - it appears the only way to get the needed +/0/- is using two four leg items. As the neutral and ground wires (U.S three prong AC plug) in my home are tied back to the same bus bar in the service box, it seems one quad should be enough. But unless someone has actually successfully used such a configuration in an amp, I best stick to the Pass PS diagram.
TNX
Diode Bridge Theory.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 10th August 2013, 09:32 PM   #1232
6L6 is offline 6L6  United States
6L6's Avatar
Burning Amp BA-3
Bob - if you arrange your secondaries as a centertap, you can use one bridge for a +/0/- supply --
Most of the factory Pass Aleph amps were wired this way.
Old 10th August 2013, 10:05 PM   #1233
You'r my hero !! I'll do some fiddlin' and post what I find.
Bob M.
Old 11th August 2013, 02:04 AM   #1234
Completed today's assignment Professor 6.
A fun exercise just different enough from what Iv'e done in the past to make it a good lesson. Getting + 25.5 and -25.5 to center.
Thanks !!!
Bob M.
Old 11th August 2013, 02:43 AM   #1235
6L6's Avatar
Burning Amp BA-3
Awesome! I'm glad it's working as expected.
Old 11th August 2013, 06:37 AM   #1236
slr 5000 is offline slr 5000  Australia
hi all
can we use semisouth r100 here to replace irfp240 in the se output stage and using 1 x pair per side
Sheafer
Old 11th August 2013, 09:16 AM   #1237
Itsmee is offline Itsmee  England
Itsmee's Avatar
Originally Posted by slr 5000 View Post
hi all
Sheafer
Have a look at the Aleph Jango post #13.
Note, the pot on the LTP is 500R not 500K.
The Aleph Jango
Old 11th August 2013, 10:14 AM   #1238
OK thanks
so by the looks of it they can only be used in the pp output stage to replace the irfp9240 with a change in the bias adjustment
not really worth the trouble correct? as we still need to use the irfp240
cheers Sheafer
Old 11th August 2013, 10:42 AM   #1239
Itsmee's Avatar
The circuit is a modified Aleph J which is a single ended output, the IRFP240 form the classic Aleph modulated constant current source, fitting R100 here could be done but would probably be a waste.
Keep the other R100's as spares, or wait until the J2 is out of production and the schematic becomes available.
Old 11th August 2013, 11:48 AM   #1240
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Burning Amp BA-3
Juma's reg supply for his 2sk2013/2sj313 F5 version
( hope he won't mind this )
File Type: gif juma's reg supply for 2sk2013 2sj313 F5.gif (11.0 KB, 273 views)
Burning Amp BA-3Hide this!Advertise here!
Burning Amplifier BA-1 Variac Pass Labs 356 18th January 2017 12:54 AM
Burning Amplifier BA-3 Nelson Pass diyAudio.com Articles 39 14th October 2016 12:36 PM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 03:53 AM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 04:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 03:35 AM
Copyright ©1999-2017 diyAudio
