Burning Amp BA-3
Burning Amp BA-3
Old 17th July 2013, 07:28 PM   #1051
generg is offline generg  Germany
generg's Avatar
Burning Amp BA-3
was it so alogical?
there is the S connection in BA-1 controlling the bias....
and he wants to use not only one outputboard but two...
both outputboards show the S pin on both sides and he asks if is it enough to connect one of the S pins of the first output board and must the S pin of the second board also connected to the S pin of the first board....?
really difficult without pictures I understand .....
I looked for the pictures at the shop, but the quality is so bad you can not see the S pin.....
and the First Wtt is......a really First Class PSS Idea
Old 17th July 2013, 07:45 PM   #1052
bcmbob is offline bcmbob  United States
If a second output board (six additional power transistors) is added in series, is there a need to connect the "S" pads between those two output boards. Or is sensing only the first resistor on the OB closest to the bias board sufficient?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 17th July 2013, 11:11 PM   #1053
william2001 is offline william2001  United States
william2001's Avatar
No need to connect the "S" pads together. The bias circuit is only looking at the voltage drop across that one resistor to control how much the bottom set of power transistors are conducting. The important thing is that all of those are well matched of course so that they share the current equally.
This is a beast of an amp regarding heat dissipation, remember you can easily dial in the amount of idle current by the value of R131 if needed as stated in the article. I forgot what I ended up with there, 30k or something, lower value=less current/heat.
Old 17th July 2013, 11:22 PM   #1054
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
Burning Amp BA-3
Bob,
When you're done with this thing I won't have to ask how it sounds...I'll be able to hear it at my house.
http://www.evancotler.com
Old 17th July 2013, 11:51 PM   #1055
Thanks William, that keeps wiring simple. I didn't match the power transistors but I did get a matched set from buzz for the front end. If I like the sound I'll be happy to circle back and upgrade as necessary. My plan is to get the amp operational as stereo first, and then add the second output boards after I get a feel for what's happening.
The heat management is at the core of this build and will be interesting indeed.
evanc, I have no frame of reference for the power/slp, but my long standing curiosity will soon be answered. Should I be scared
Bob M.
Old 18th July 2013, 12:07 AM   #1056
Burning Amp BA-3
not scared .... excited.
What do you use for speakers?
Old 18th July 2013, 01:01 AM   #1057
My mains currently are the Sunflowers, a bit on the low efficiency side. The second pair is my DIY 15 year standard that has two Vifa 6.5" and a Morel MDT 30 tweeter in MTM. Crossovers done on Leap system by Masisound. They can play REALLY loud and handle a lot of power with a very nice presentation. Both will probably be overpowered but one always needs an excuse to build something new.
Bob M.
Old 18th July 2013, 10:00 AM   #1058
post 1051
Is the S pin the trace that connects to R132?
+D, +v, -V & OUT are all labeled.
S pin should have a label and show a terminal on the schematic. Leaving it unlabeled is confusing !
regards Andrew T.
Old 18th July 2013, 10:46 AM   #1059
generg's Avatar
Burning Amp BA-3
Yes Andrew, the S Pin is that trace ging to R132......and it it seems to be unimportant how many pairs are behind the first pair giving the sense S to the neg bias circuit, isn't it?
Old 18th July 2013, 11:11 AM   #1060
Yes, but it does rely on adequate matching of semiconductor devices and resistor devices.
If one wants to check the current imbalances of the output stage semiconductors, then the resistors MUST be matched to far better than the tolerance you expect of the semiconductors
Aim for better than 1% range of resistor values (+-0.5%) and preferably +-0.2%.
regards Andrew T.
Burning Amp BA-3Hide this!Advertise here!
Burning Amplifier BA-1 Variac Pass Labs 356 18th January 2017 12:54 AM
Burning Amplifier BA-3 Nelson Pass diyAudio.com Articles 39 14th October 2016 12:36 PM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 03:53 AM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 04:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 03:35 AM
