Burning Amp BA-3 - Page 103 - diyAudio
Old 4th July 2013, 12:17 AM   #1021
buzzforb's Avatar
Make sure you measure offset before the output cap. Other than that, it is pretty straightforward. Ask any questions you have. Jfets are good if you have between 6-7ma across jfet Rs.
...Shape the sound , Man!
Old 4th July 2013, 12:38 AM   #1022
6L6 is offline 6L6  United States
6L6's Avatar
Originally Posted by bcmbob View Post
Is there a published build and/or initial start-up/test/adjustment procedure for the BA-3 front end somewhere on the forum? I haven't located one yet. Would be good to confirm proper operation before I hook it up to something else.
It's essentially an F5 in topology, so treat it like an F5 ---
Turn down the bias pots, neutralize the 2nd harmonic pot.
Get out your three meters just like an F5. Turn up the bias pots equally until there is some voltage across R10 and R11.
Increase bias about 20% at a time, and null your offset at each increase.
Lather, rinse, repeat until you have 1V across the output source resistors and zero offset.
That should be good.
Old 4th July 2013, 12:45 AM   #1023
bcmbob is offline bcmbob  United States
Thanks All !
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 4th July 2013, 03:28 AM   #1024
He's Back
Does anyone have a part number(s) for P1/2 P3 on the BA-3 FE board. I ordered these and received standard vertical three pin trimmers. From the traces, I'm assuming all four leads on those pads are necessary. I spent some time at Mouser but can't put my finger on the exact combination of orientation and pins.
Bob M.
Old 4th July 2013, 03:37 AM   #1025
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
Only three pins needed. I used regular vishay multitude trimmers.
http://www.evancotler.com
Old 4th July 2013, 03:57 AM   #1026
6L6's Avatar
The offset pin and the in-line pin are there for convenience, to fit various types/brands of pots.
The ones you have are great.
Old 4th July 2013, 10:37 AM   #1027
Good to hear that.
Moving on - Thanks.
Bob M.
Old 15th July 2013, 01:21 AM   #1028
Due to some space requirements, I would like to have a single row of caps in the power supply. Does this look correct?
And - if I wanted additional caps they would be inserted to the right of the purple ones ?
Bob M.
Old 15th July 2013, 09:48 AM   #1029
Yes.
The green T junction away off to the right hand side is your MAG.
The R of the CRC is a little unconventional in that both appear in the +ve side of the cap banks. I think that theoretically they perform just as well as doing one in +ve and one in -ve.
Remember to keep twisted pairs/triplets to as close as the PCBs allow.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 15th July 2013, 01:55 PM   #1030
Thanks Andrew.
Bob M.
Burning Amplifier BA-1 Variac Pass Labs 356 17th January 2017 11:54 PM
Burning Amplifier BA-3 Nelson Pass diyAudio.com Articles 39 14th October 2016 11:36 AM
Burning Amplifier BA-1 Nelson Pass diyAudio.com Articles 3 24th October 2011 02:53 AM
WTB: Burning Amp BA-1 or BA-2 jdubs Swap Meet 0 23rd March 2011 03:16 AM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
Copyright ©1999-2017 diyAudio
