Old 20th August 2011, 09:42 PM   #1
buzzforb's Avatar
Default Toroid wiring problem
I bought two 483VA amveco trafos off of fleabay. Problem is, wiring is different than what i am used to and i can't find wiring diagram anywhere. It is 0-100-120 primary, 18VA@10A, 24VA@8A (30% cycle duty), 36VA@6A (50% cycle duty).
Two concerns are wiring layout and size. None of the color coding matches any of their or anybody elses current scheme and wire seems awlful thin for so much current. I believe the primary is wired as follows:
Black - 0
Brown - 100V
Red - 120
Orange - 0
Yellow - 100
Blue - 120 (I have green and not blue)
Secondary
Green (this and red below are much larger ga. wires than all the others)
Red
Blue
Brown
White
Orange
Is there any way to test the primary and secondary wires?
Old 20th August 2011, 10:43 PM   #2
nigelwright7557's Avatar
Simplest way is to power it up and look for AC voltages on secondaries.
A resistance check will show which secondaries are connected to which.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 20th August 2011, 10:47 PM   #3
Aren't the primary and secondary wiring codes listed on the label?
Mike
Old 20th August 2011, 10:56 PM   #4
buzzforb's Avatar
Mike
No.
OK.
Old 20th August 2011, 10:58 PM   #5
An AC wallwart or small filament transformer (or Variac) can make this less exciting than using the mains AC.
Old 20th August 2011, 11:05 PM   #6
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
ponder this
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 20th August 2011, 11:09 PM   #7
buzzforb's Avatar
Thanks ZM. Just trying to be safe. I will try with variac.
Behringer CX2310 Toroid wiring anilva Analog Line Level 5 1st June 2011 01:29 AM
4000VA Toroid Transformer Problem Dr Wattson Power Supplies 41 19th April 2010 11:51 AM
Wiring Toroid 14V non center tapped for PSU civilmonkey Chip Amps 7 23rd September 2006 08:12 PM
Toroid Wiring for Chip Amp hongrn Chip Amps 10 26th October 2005 07:54 PM
Dual primary wiring for Plitron standard toroid sardonx Chip Amps 6 3rd August 2005 05:16 AM
Page generated in 0.09392 seconds (75.62% PHP - 24.38% MySQL) with 11 queries
