Old 11th August 2011, 09:40 PM   #1
Munga is offline Munga  Australia
Default Pass ZEN cheapo ebay special.
Hi All,
Does this look like a copyright infringement to anyone? Does it appear to use a Nelson Pass design or are they just trying to use his name to sell them?
eBay Australia: Buy new & used fashion, electronics & home d?r
Old 11th August 2011, 11:21 PM   #2
The one and only
Nelson Pass's Avatar
Trademark infringement.
Old 12th August 2011, 05:02 AM   #3
You should take it as a compliment, and then sue them. :P
Old 12th August 2011, 07:26 PM   #4
tiefbassuebertr's Avatar
Whether or not trade mark infringement - I doubt whether there is any justification for such amp devices with only the unimportant devices with respect to the costs;
The really expensive devices are always not mentioned in such offers:
Heatsink, transformers and capacitors.
An exception can be found here (information unfortunately only in German):
Home - André Buscher Audiotechnik - Puristische Eintaktverstärker
(Single Ended Power Amplifier Modules for Purists)
Start by only 250 euros for a stereo module include all parts except the enclosure; from my view not expensive for a 2-CH completly power amp module.
If I tend to buy a PCB with parts as show about
http://www.ebay.com.au/itm/ws/eBayIS...#ht_1810wt_905
it is better to buy a SRBP matrix board from Vero like this
http://uk.rs-online.com/web/p/protot...oards/4853892/
and the components individually (then I can choice high quality caps and must not accept the low-cost caps from the provider in HongKong).
The number of simple and good circuits for SE amp projects is alone here on diyaudio very large.
Old 12th August 2011, 07:31 PM   #5
Mr Teal is offline Mr Teal  Canada
Obviously not trademark infringement, this amp uses MOSFET tubes.
Reference ZEN line design single-ended A senior Liangsheng amp on the board with a rectifier filter, dual-channel fully independent design (ground are completely independent) using FET voltage power supply. Regulator, constant current control, amplifier tubes are used new original IRF610 MOSFET, quiescent current 380MA! Adjustable. Mellow sound, music, gorgeous, quite a tube amp style. Load capacity, pushing 32-600 EU good performance headset can also be pushed directly to the speaker in Europe, 4-8, when the little 5W amp, the sound is very good. FET design of the edge of the board can be easily fitted to any size of the radiator, if it is aluminum chassis, you can also install the tube horizontal, the base plate when the heat is very convenient
Where do you think they got the "used new original IRF610" FETs?
Old 12th August 2011, 10:09 PM   #6
The one and only
I find that when I use "search and replace" functions to edit earlier product
text I get results like that.
Old 15th August 2011, 04:42 AM   #7
PPFFFFTTTT!!! Papa uses IRF610 as preamp transistor. This copycat isn't even a good copycat. Pathetic and insulting.
Peace,
Dave
Old 15th August 2011, 07:19 AM   #8
I don't understand this.
By exactly look to the images I read the logo from Siliconix on the surface from the IRF610.
Old 19th August 2011, 04:03 PM   #9
About MOS-FET tubes - it´s written in the description. I think this guy is using a HUGE PSU since he states that the current is 380 MA!!! Ok, maybe he meant 380 mA?! ;-)
Karsten
Old 19th August 2011, 04:25 PM   #10
slownlo is offline slownlo  United States
Guilty as a sex maniac in a brotel with a credit card...
I bought them because they made building the design simpler...
sounds pretty good...lacking bass
FREE: Pass Zen & Bride of Zen Kits. axissilverhand Swap Meet 10 2nd December 2010 06:01 PM
Value for input cap in special hi pass application Zero One Chip Amps 6 14th May 2009 01:54 PM
Pass on Ebay Jarno Pass Labs 0 17th February 2004 07:22 PM
Cheapo transformer substitution for Zen cmcgraw Pass Labs 15 26th December 2001 04:01 AM
Page generated in 0.09363 seconds (86.01% PHP - 13.99% MySQL) with 11 queries
