diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   Aleph30 with IRFP044's: Bad Idea? (http://www.diyaudio.com/forums/pass-labs/19437-aleph30-irfp044s-bad-idea.html)
Dennis Hui 26th August 2003 05:34 PM
Hi all,
I'm planning to build an Aleph30 and I happen to have a number
of IRFP044's on hand.
The rails of the A30 are at +/-25V. Given the drain-to-source
breakdown voltage of only 60V for the IRFP044's, I suspect they
may not be suitable.
Should I give the 044's a try or would that be flirting with
disaster? Or perhaps I should just get some IRFP240's?
Thanks,
Dennis
Andypairo 26th August 2003 06:43 PM
I'd rather try a Aleph-X, which has lower rails for a given power and is claimed by someone to be even better than the regular Alephs.
I'll try it myself and then will compare with my Aleph 30.
Cheers
Andrea
Nelson Pass 26th August 2003 08:24 PM
I believe 044's will work just fine. Might have to adjust
any Drain-Gate compensation.
wijgers 26th August 2003 11:13 PM
IRF244
Where to find them?????:scratch:
Hi, Im a Newbe in making Amplifiers, but after some reading of several threads it came a bit clear to me. How the circuits are working and what everything stands for.
I want to upgrade my system (Commercial NAD 317 integrated amp, NAD 514 CD, Dali 505 Speakers, in which the filter allready had ben changed)
Amp has an extra set of Pre out.
I was thinking about A 30-40 Watt Amp. Don't need that much and planning to get rid of the amp by making an BOSOZ.
So me eyes felt on the Aleph3 / 30(thanks to MR Pass). and the A40. First I will try to make the Aleph. If that works, make it a continued story.
But in a store Near Rotterdam (dordrecht) Ther where no IRF 244. :bawling
Does anybody in the Netherlands where to buy the Matched IRF244, or are there substututes without makking any changings off bias and current gain?
Nelis:
Dennis Hui 27th August 2003 02:27 AM
Thanks for the advice! Will give the 044's a try.
Dennis
Netlist 27th August 2003 05:48 AM
Re: IRF244
The IRF244 is obsolete.
You could try IRFP244.
It has about the same specs as the IRF244.
Ooh, and welcome to the forum.
/Hugo
edm 27th August 2003 08:00 AM
@wijgers:
Go here:
http://forum.hifi.nl/index.php?act=ST&f=27&t=1417&
Most of the people there also post here, so perhaps they answer here.
(see e.g. http://www.diyaudio.com/forums/showt...threadid=19390 or http://www.diyaudio.com/forums/showt...threadid=15906) Perhaps you could also try to contact them through this forum.
Resources saved on this page: MySQL 18.75%
