#21 |
It would be interesting if you could swap some SIT devices with the guy who heads up Digital Do Main in Japan. Apparently, he's keeping some of the old Tokin SIT product line alive for his amplifiers.
#22 |
The one and only
Don't need to. I have a small stash of those.
#23 |
Interesting. Have you compared curves?
#24 |
Can anyone post a link that explains what exactly are the SITs, how they work, etc. and why are they better than regular transistors ?
I saw on the Internet that they are supposed to be 1000 times faster than an ordinary transistors ? SAY WHAT ? |
#25 |
naah
they're nothing special just sand triodes
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#26 | |
The one and only
tube Triodes, but can do so at voltages and currents of interest to loudspeakers, removing the need for transformers, heaters, and so on. I am writing a nice little article on the subject which will make an appearance after a bit.
#28 |
This is the link where it says that they are 1000 times faster than transistors:
New Scientist - Google Books However that article is from the 80s so the regular transistors have progressed a lot since then. The only useful link I found that explains how they work is this: Junction field-effect transistors : SOLID-STATE DEVICE THEORY It appears that they are JFETs with the gate inside the channel as opposed to next to it. Any more info available ? |
#29 |
Speaking about a use of SITs, I would remind, that the working point they are usually implemented at is chracterized by relatively low Drain-Source resistance. What this can be useful for?
As in a case with NFB and THD, it is better to insure maximum linearity before the closing of NFB loop. Same is true with the output impedance Zout. Usually it is lowered by the action of NFB. But, again, much better to insure quite low Zout, before the closing the NFB loop, and this could be done just due to triode-like output characteristics of SITs. |
#30 | |
P.S. Looking forward to the article! |
| SIT-Preamp | VladimirK | Solid State | 36 | 27th August 2011 08:36 PM |
| How close can one sit to multiway horns? | bvan | Multi-Way | 6 | 7th November 2010 11:20 PM |
| 1st Pass at 1st Phono Preamp; Comments? | nullspace | Tubes / Valves | 16 | 1st December 2009 08:47 PM |
| SIT Power Amplifier??? | mad_z | Solid State | 8 | 26th January 2009 08:31 PM |
| New SIT - old problem | StevenOH | Parts | 2 | 13th June 2008 10:46 AM |
| Page generated in 0.11256 seconds (83.19% PHP - 16.81% MySQL) with 11 queries |
