Would it be ok to use 2W .47ohm resistors as opposed to 3w in the power supply?
#2 |
Best to use 3w or better. They get real hot.
I build, therefore I am. |
#3 |
OK thanks.
#4 |
I * I * R = P
1.2 * 1.2 * 0.47 = 0.6768 W So, 2W resistors are fine here (except if you have 4 Ohm speaker and you drive the amp to full power for long period of time). |
#5 |
Well I may hook the amps up to a 2 ohm speaker load at some point and I would rather be safe then sorry. I just happened to have 2W available. For 3w or bigger I need to make an order.
Does quality of resistor in this area matter much? Will you notice a difference between a sand-cast or something better? I am guessing not. |
#6 |
I don't like the good things to go to waste. You can put 2 x 0R47 in series and parallel them to another two in series. That's equal to one 0R47/8W resistor.
When it comes to quality, aim for low temp. drift and precision, don't waste the money on boutique parts... |
#7 |
I just found a local source of just what I need (no crazy shipping fees). I am going there tomorrow.
#8 |
five 2r2, 600mW in parallel give an effective 0r44, 3W
regards Andrew T. |
| Rare Sony PS-F5 Portable Turntable | gkrieg | Swap Meet | 1 | 25th August 2010 05:42 PM |
| question re: sony ps-f5 portable turntable | voicegyrl | The Lounge | 0 | 31st July 2008 09:36 PM |
| Old radio quick question re PS | Simpleton | Tubes / Valves | 17 | 25th August 2006 04:25 PM |
| Sony PS-F5 info needed | dubmaster45 | Analogue Source | 1 | 8th December 2004 05:01 AM |
| Quick Aleph2 PS question/opinion | vinay | Pass Labs | 2 | 10th February 2003 04:16 AM |
| Page generated in 0.09016 seconds (78.42% PHP - 21.58% MySQL) with 10 queries |
