Old 25th August 2003, 06:20 AM   #1
Unhappy Help Aleph 3 Problem!
Hi all
I bought a pait of Aleph 3 boards from Kristijian a while back, put the amp together and everything was working great until today :-( one of the channels just died. The LED does not come on and initially I thought there might be a problem with the connections - I tried wriggling the speaker connections and I saw sparks at the speaker connector!
At this point I disconnected all the inputs and outputs and examined the boards. Nothing seems to be fried, all resistors look ok. Does anyone have any thoughts on where I should start from?
I checked the power supply circuit and that part seems just fine. If I look at the circuit (link below) it looks certain that the 244 device on the top right hand corner closest to the LED has blown, any thoughts?
http://web.vip.hr/pcb-design.vip/aleph-3.html
thanks in advance
vsr
Old 25th August 2003, 06:41 AM   #2
Cradle22's Avatar
Hi!
Although having never built an Aleph so far, I think that most of the time the integrated devices (transistors, diodes) are the cause for a fault, so check first the power transistors, then the drivers.
But a fault in power transistors can also cause the emitter resistors to blow (the 0.47 ohms), so you might check them, as well.
And always check devices unsoldered from the circuit, since connection to other devices changes the values you get while measuring...
And look for the reason why a specific device has blown... too much heat? bad solder joint? Short with probes (unlikely in your case, but my #1 cause for failure )? Or bad luck...?
Bye,
Arndt
A Sacrifice For Freedom
Old 25th August 2003, 06:48 AM   #3
Netlist is offline Netlist  Belgium
Netlist's Avatar
Default Re: Help Aleph 3 Problem!
Hi vsr
Assuming you have a DMM, you should provide some more details about the voltages you have on the critical points in the circuit.
What do you measure at the output? DC? How much?
What voltage between emitter and collector of the MPSA18 of the current source?
What voltage over the source resistors and so on.
The link you provide is a nice schematic, but for more in dept measurements the PDF at Passlabs is better IMHO.
Keep us informed and (small but important warning) : Discharge the big cans properly before poking around with the soldering iron :nod;
/Hugo
Old 25th August 2003, 03:26 PM   #4
Default Measurements
Hi
thanks much for your posts. I made some measurements. The output is just DC at 27V !! There is no voltage between C and E of MPSA18.
thanks
vsr
Old 25th August 2003, 03:48 PM   #5
Netlist's Avatar
First thing to do is measure the fets.
You will have to take them out to measure accurately.
Here's a good link to know how to measure them:
http://www.eatel.net/~amptech/elecdisc/ampfail.htm
Start with the diff-pair then work yourself trough the outputs.
You can always compare measured values with the good working side.
Check the zeners as well.
/Hugo
Old 25th August 2003, 06:00 PM   #6
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
27V on the output... does that mean at the speaker terminals or on the out-put transistor's.?
Old 25th August 2003, 06:04 PM   #7
Hi Jason
The 27V DC is on the speaker connections on the PCB (measuring between +ve speaker out and ground).
thanks
vsr
Old 25th August 2003, 06:08 PM   #8
Banned
to me that doesn't sound good at all OUCH!! I'm clad that I'm looking at all these aleph post's. as I'm still building the Aleph 2's that i have now.
Old 25th August 2003, 06:36 PM   #9
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: Measurements
Hi
thanks
vsr
Which MPS18? There are two in the diagram you posted.
What's the voltage across the 390 Ohms load in the input stage?
If you have drafted this diagram, why don't you number the components? Makes any discussion (and your own work!) much easier.
Jan Didden
Old 25th August 2003, 06:44 PM   #10
Default MPSA18
Hi
Sorry, the MPSA 18 I was referring to is the one on the top of the circuit.
I will take the measurement across the 390 ohm later and post it here.
As for why I didnt number the components, I did not draft the figure, its from Kristijan's web site, the Aleph 3 service manual at www.passdiy.com also has the same circuit and the MPSA 18 I was referring to is labelled as Q105.
thanks
vsr
problem with R44 on Aleph P 1.7 Stefanoo Pass Labs 15 9th October 2007 12:57 PM
Problem with aleph p 1.7 gabflo Pass Labs 7 2nd September 2006 05:50 PM
Problem with Aleph 2 ppesa Pass Labs 1 31st January 2006 07:44 PM
Aleph 2 problem!Help... nar Pass Labs 14 1st June 2003 03:42 PM
Aleph 5 PSU problem please help? xsnailx Pass Labs 10 4th March 2003 06:28 PM
Page generated in 0.10557 seconds (81.31% PHP - 18.69% MySQL) with 11 queries
