#11 |
I use 8 mosfets, 4 per side.
Each one carries about 1.25 A, which means 275 mV on source resistors, slightly different from the 0.5V you use as "reference" value.... where does it come from? On the Aleph30 manual this voltage value is of about 250 mV (and the equivalent of AlephX's R34 is 820 ohm), in the Aleph60 this voltage is 370 mV and the resistor is about 1K.. does this mean something? Cheers Andrea |
#12 | |
Jarek |
#13 | |
/Hugo |
#14 |
I used 2k//4k7 which is about 1k5 and also the 30 ohm from output to gnd.
While testing I also noticed that while the differential output can output a perfect sinewave of more than 13Vrms, the single ended outputs dont'.... did anyone noticed that also? Cheers Andrea |
#15 | |
Edwin |
#16 | |
Jarek |
#17 |
Well, I mean that, running it unbalanced mode, the output waves of the two halves (referenced to GND) are very different in amplitude (but this seems normal).
The funny thing is that, when the input signal is strong enough to make the more "driven" side clip the other half compensates for it, giving a ugly waveform that, summed to the clipped other, makes a almost perfect output waveform. I wish I had a digicam... a image is better than 1000 words sometimes... Another thing: I tried to see on my scope the AC current flowing in the lower mosfets but, while I expected to find a sine wave, I only see it at very low levels; raising the input voltage it becomes a more peaky waveform. The current on the upper side is instead perfectly sinusoidal: does this mean that the current source is doing all the job? Cheers Andrea |
#18 |
Jarek |
#19 | |
After reading through various posts of the original Alephx thread my guess would be that there is something wrong with your diff-pair current source. -7V is simply not normal. Are you sure you have no bad soldering or wrongly connected components? Also, the 1k5 resistors could indeed be too low. What are your values of R12/R34? Greetings /Hugo |
#20 |
Jarek - the link you posted was very useful, I followed some of Nelson's suggestions (R46-R47 are now back to 4.7k) and things got better.
The big change was when I also changed R14 (R31) and R32 (R15) to 1.5 k and now things are going even better. Hugo - The waveforms I obtain are now quite good, the only thing left to trim is the AC gain of the current source, which seems to have too much gain: if I measure the AC current on the low side I get about 300 mA pk-pk, while on the positive side I have almost 900 mA pk-pk... maybe R12/34 is too high (1.2k, as from Grey's schematic) ? I'll try changing it and see what happens... Cheers Andrea |
| DC-offset problem | Bootstrapper | Solid State | 12 | 6th October 2007 09:25 AM |
| DC offset problem | whatsnew | Chip Amps | 17 | 2nd January 2007 09:26 PM |
| DC offset problem | maxw | Chip Amps | 38 | 17th May 2006 03:31 AM |
| DC offset problem Aleph 5 | Adrie | Pass Labs | 6 | 6th March 2005 04:05 PM |
| Aleph X DC offset | tomchaoda | Pass Labs | 11 | 29th October 2004 10:37 PM |
| Page generated in 0.13257 seconds (83.00% PHP - 17.00% MySQL) with 10 queries |
