I'm beginning a F5 build. So far I've almost finished the enclosure and started getting the power supply portion built. I tried to P2P the power supply using the First Watt schematic. I thought I was finished, so, I hooked it up to my dim bulb tester (100W light bulb). The bulb is full bright (everything in the power supply connected) and i saw a little smoke come from one of the connections on one of the caps. Does the photos look correct? The transformer is an Antek AN6218 (18v secondaries). With the DC sides of the rectifier bridges disconnected, I'm measuring about 17.7v across the DC side of the rectifiers (shouldn't it be close to 25volts coming out? - also the bulb tester doesn't light up). Also, instead of the .0033 line cap, I have a .0082 in it's place (from an old computer power supply - is this value OK?).
#2 |
couple more pics
#3 | ||
17.7*sqrt(2)=25 V -> ok! From the photos I cannot see an obvious error, but there is definitely one somewhere. Quote:
Hannes
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#4 |
Why do you have the groundstar on the second set of caps?
The first set of caps has a very high current and voltage ripple compared to the ones after the resistor. By the looks of it, those are panasonic caps, I have some of the 10000uf ones, and they are about 0.36 ohms each and have a ripple capacity of about 4A on a good day. even paralleled they might not be up to the task at hand. Download Duncan's PSUD and simulate what is going on. It is pretty easy. Of coarse it could just have been some solder flux smokeing off. Last edited by digits; 27th July 2011 at 06:59 AM. |
#5 |
On your voltage measurement..... keep in mind you are not measuring pure DC when you measure the output of your PSU rectifiers without the caps connected. Without the filtering of the caps, you are seeing full wave rectified DC, that will be about 70% of your final PSU output voltage. In other words, if you are seeing about 15 volts now, after filtering (and without a significant load, you'll be seeing 141% of your present measurement. That will give you about 25 volts--right where you should be.
Also keep in mind that without a load on your PSU transformer secondary, the transformer PRIMARY will also not see much of a load. Therefore, your transformer will not cause a large voltage drop in the mains voltage--and you'll be applying almost all your mains voltage to the light bulb...therefore, the bulb will be bright. Until you load down your PSU outputs (i.e., with the capacitors, bleeder resistors and amp modules attached [and drawing some bias], yourlight bulb tester will appear to be pretty bright. You might want to check the gauge of your wiring between your full-wave bridge rectifiers and caps, and within the cap banks. Same goes, for when you wire between the PSU and the amp modules. I think your wiring is pretty thin. I used, if I recall, about 14 gauge wire...... so pics attached for your info. I have not done a wire-by-wire tracing of your pics. You might want to triple check, and press on from there. |
#6 |
I consider 100W for the bulb tester too big for good protection.
If the wiring and assembly has already passed the 40W bulb test then you can start increasing the bias using a 60W bulb and go a stage further with a 100W bulb. After that you have to work direct on line, although 10r low power resistors between the cap bank and the new build do help reduce damage when you go askew. Full bias will require 1r0 resistors and maybe even two 1r0 in parallel on an F5.
regards Andrew T. Last edited by AndrewT; 27th July 2011 at 07:38 PM. |
#7 |
wire gauge is unlikely to be a problem. I contend that smaller PSU wire gauges allow the amplifier to perform better.
regards Andrew T. |
#8 |
#9 |
Yes. That little r is very helpful. Even at the decoupling on the PCB. The earlier r in the connections adds up to create a more effective filter.
regards Andrew T. |
#10 |
yup ;
but only if one is looking at world solely through PSUD in my book PSU with lowest internal impedance is best ; better to put some greenies in better caps , or more caps - than trying to cure with wimpy wires and/or resistors in-line at least when we are speaking about 1-off building , not commercial one (where one must count on myriad other issues)
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
| Thermistor Location for F5 power supply | calvinhpk | Pass Labs | 37 | 10th April 2012 05:53 PM |
| WTB F5 power 12V input smps power supply | DJNUBZ | Swap Meet | 2 | 19th June 2011 01:41 AM |
| F5 boards and Power supply completed | NYCOne | Swap Meet | 0 | 3rd February 2011 04:59 AM |
| Need parts for [2] f5 amps and power supply | elecres | Swap Meet | 2 | 6th September 2010 08:59 PM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
| Page generated in 0.10643 seconds (86.36% PHP - 13.64% MySQL) with 11 queries |
