Old 20th July 2011, 07:00 PM   #1
BigE is offline BigE  Canada
Default Adding bass to an F5?
A buddy of mine built an F5, and is having problems with getting enough bass out of larger speakers, like watson lab model 10, tannoy dmt215, maggie 1.6. for example, Bjork's "All is full of love" has tons of deep bass that reaches out and blooms into the room with my modified Phase linear 400 and watson lab model 10. With his f5, the bass never leaves the speakers -- no bloom at all. This track is known for it's insanely rich and room filling bass.
He's hotrodded it to a higher bias, and claims 38 wpc.
He's got 37,000 uF Kendial caps in it, and a 400 VA toroid.
Are the caps bass shy, or is it just that the speaker needs more power? Can he achieve his goal of room filling bass by increasing PS capacitance?
Thank you.
Old 20th July 2011, 09:20 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
let him make hot-rodded F5
you'll find that as cascoded or full blast F5
input is cascoded , outputs doubled
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 20th July 2011, 11:39 PM   #3
Itsmee is offline Itsmee  England
Itsmee's Avatar
Is that total or per rail?
It may need to settle in, give it 100 hours use before changing anything.
Old 21st July 2011, 12:45 PM   #4
Botte is offline Botte  United States
Botte's Avatar
Try a .47ohm resistor in series with each speaker. This will add some bloom to the base as it lowers the damping factor.
Old 21st July 2011, 01:07 PM   #5
flg is offline flg  United States
flg's Avatar
No one has mentioned any testing of the amp? Try testing freq response into an 8 ohm resistor. Is it the amp or the load?
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss
Old 21st July 2011, 01:53 PM   #6
Per rail. It should be settled in by now.
Old 21st July 2011, 01:54 PM   #7
Interesting, I'll pass it on.
BTW: What wattage of resistor?
Old 21st July 2011, 03:56 PM   #8
Botte's Avatar
5 Watt should do it.
Old 21st July 2011, 05:36 PM   #9
I have the Cviler boards for double outputs. With them plus cascoded front end, what is max rail voltage (for good effect, not absolute max) and bias? assuming plenty of sink...
Russellc
Old 21st July 2011, 05:46 PM   #10
My F-5, standard single pair outputs, standard rail voltage and bias (but dual mono with 2 300VA transformers) playing into JBL 2235H in 5 cu ft tuned to 32 hz, b&C DE 250 compression driver with QSC wave guide has Bass, Bass all over the place....
Russellc
F5 Cascoded - an alternative for my interest in the Balanced F5 NYCOne Pass Labs 159 24th March 2011 05:23 AM
Adding bass boost to Mini3 spaceconvoy Chip Amps 2 1st March 2011 06:05 AM
Adding a mid bass cabinet to a existing 2-way speaker. MarzZ Multi-Way 0 24th December 2009 04:55 AM
Will adding a 10H/125mA choke hurt bass performance andy2 Tubes / Valves 10 22nd February 2006 12:55 AM
Adding Treb and Bass adjustment?! cadman Tubes / Valves 52 22nd December 2002 10:08 AM
Page generated in 0.10288 seconds (78.12% PHP - 21.88% MySQL) with 11 queries
