Toroid Transformer mounting question
Old 18th September 2011, 10:13 PM   #21
pizzachef is offline pizzachef  United States
sorry for the noob question, but i am getting someone else to drill and tap my case and i canot find what size the mounting bolt is that comes with antec torroids. its not on their spec sheets. can anyone help?
Old 18th September 2011, 11:55 PM   #22
CanAm Man is offline CanAm Man  United States
Did I misread your note--are you going to TAP the hole for the Antec on your chassis? No need to do so--you already have a nut...! Just drill a hole slightly larger than the bolt's diameter (you can "eyeball" that.....) and use the bolt/nut/torroid gaskets/large retaining washer and a good lockwasher, and you're done.
For drilling and tapping holes for other machine screws/bolts, your buddy should have a vernier caliper (or micrometer) and a thread pitch gauge? If so, he can tell you the bolt's specs. If not, a GOOD hardware store (like an Ace Hardware) should have templates that will tell you diameter and pitch....
Old 11th December 2011, 05:41 PM   #23
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
How about these
These are my mini aleph's, they are the smd version.
Old 11th December 2011, 09:46 PM   #24
AudioSan is offline AudioSan  Norway
what about them?
Old 14th December 2011, 06:03 PM   #25
Eric is offline Eric  United States
Eric's Avatar
Originally Posted by h_a View Post
Alu does not provide any shielding as also iron does not. Count only on mu-metal for significant shielding. Hannes
Hannes, Do you have any sources for mu-metal? The only one I've been able to find is at McMaster-Carr, though it seems a bit expensive for very short lengths.
Thanks,
Eric
My DIY Basement Theater, Aleph-X Amps, Avro Open Baffle Speakers, LDR based DCB1 + BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
Toroid Transformer mounting questionHide this!Advertise here!
Toroid mounting getting hot ... deduikertjes Power Supplies 10 15th February 2007 05:21 PM
SMPS toroid transformer question thoriated Power Supplies 11 6th April 2006 02:13 AM
Toroid Mounting Caution bzdang Chip Amps 0 23rd April 2004 02:25 PM
toroid transformer mounting question thoriated Solid State 3 12th January 2004 04:45 AM
Transformer mounting question kilowattski Solid State 1 6th October 2003 03:19 AM
