Anybody built both and can compare the sound. The circlotron seems to give better measurements. Nelson, do you have an opinion.
#2 |
I'm not N.P. And, I havent built one in 5 years or so (A Circlotron). You say "seems to give better measurements" what measurements are those?
I think my next Circlotron will be a Lightspeed like circuit feeding a Comp JFET buffer feeding an LL7905 spliting to two R100 pair in Circlotron Config...
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#3 |
As you know, I have some new SS fets to play with and while waiting on components, I am thinking of possible implementations. I already have two sets of F4 boards that I purchased to eventually use in biamped OB. Along with topologies we have discussed in other threads, I have considered using the R085 in a preamp like GroundedGrid or other FE that could swing the voltage necessary to drive the F4. In general reading on Nelson's site, I came across the circltron article and noticed the measurements looked better than the F4, therefore I asked. It is difficult waiting for parts and even more difficult doing all this with 4 kids. Sometimes I only have time to ask questions. My building time must be as educated and as efficient as possible.
#4 |
Well, I guess your talking about Mike R's. Amazing FET Circlotron? I like that design but, I'm of the opinion the original circlotrons were followers. Mike's is not. EUVL's is also not. A common source version is interesting but it's not circlotron to me! I think Mike's version is a cross between circlotron and F5. A very good one
I think the circlotron topology would be like the F4 more if using Toshiba parts in the F4. IRFs are likely to introduce a little more second harmonic that the F4 topology typically does not have.
#5 |
All the more reason to consider it, wouldn't you agree. If nothing else, it has possibilties. I like Nelson's move towards a modular approach. Perhaps that is why power buffers are grabbing my interest.
#6 |
Are you guys talking PPP , i thought only tubes could be a circlotron ..?
#7 |
I'm not sure which one of those P things you call it? Push-Pull sounds close enough to me? I guess balanced and differential fit also?
Why do you think only tubes could do the Circlotron thing. It's just another symetrical aproach to cancel non linearity with the other "Side" of the circuit. getting the operating point in a good place for the gain elements is the important part.
#8 |
PPP is parallel push pull i believe. I have depletion mode Jfets, which are almost exactly like tubes with the exception of their response curves.
| Circlotron questions | SpreadSpectrum | Tubes / Valves | 202 | 8th May 2012 05:44 AM |
| Inductor Circlotron | carpenter | Pass Labs | 27 | 19th February 2010 06:47 PM |
| Circlotron Meditations | Michael Rothacher | Pass Labs | 60 | 4th November 2009 05:04 PM |
| Circlotron | djk | Pass Labs | 13 | 20th August 2006 03:19 AM |
| Circlotron amps | cuallito | Tubes / Valves | 7 | 25th April 2004 01:31 PM |
| Page generated in 0.09154 seconds (77.56% PHP - 22.44% MySQL) with 10 queries |
