"SiC Puppy SE Amp Using Semisouth 085 JFET
Old 19th August 2011, 04:37 AM   #81
Spooky Electric is offline Spooky Electric  Germany
Spooky Electric's Avatar
Holes, rounded notches, (thick) wire and good pincers! I guess this could look fine if made accurately. Especially when using husks for the drilled wire ends. This is at least my assembly plan for it...
Old 19th August 2011, 04:43 AM   #82
wrenchone is offline wrenchone  United States
wrenchone's Avatar
I have access to a milling machine, so milling an appropriate "U" shape in the heat spreader with a hook for the clip may not be a really big deal. Some sort of sheet metal hook bolted to the opposite side of the spreader might also work.
Old 28th September 2011, 08:04 AM   #83
wrenchone's Avatar
I've just fitted the pieces of the "SiC" puppy to a piece of pine board - with 3 transformers, this is one amp that won't be walking across the table when the bass gets heavy. It'll sport a Corian top plate (faux brown granite) to keep inquisitive fingers out of the high voltage. Tomorrow night I'll finish the power supply, and sand and paint the base board satin brown to complement the top. Having leaned my lesson with "Le Mutant", I've positioned the amp modules so that the hot air exhaust gets ejected immediately out into the open and doesn't linger around. This one also looks like it'll make it to BA. I have somewhat higher hopes for the sound of the Puppy as compared to the other two Passish amps I'm bringing, but comparison with a good source and speakers will tell...
Old 1st October 2011, 04:10 AM   #84
wrenchone's Avatar
So sad, I just finished getting the SiC Puppy up and running on its pine board. The sound is crisp and incisive (my favorite of the 3 Passish amps I've built thus far), but overlain with a patina of hum. Whether this is spray from the power transformer, power supply hum (should not be an issue with capacitance multipliers, but I need to check), or some snarky oscillation that just raised its head is unknown. Running the amp on an electrophoresis supply appears to kill the hum, so it's probably something to do with the supply. Anyway, as I really don't feel like hauling the electrophoresis supply to BA along with all the rest of the crap I'm bringing, this boy stays home until he's well. Too bad, as he may be my favorite child of the projects I've been working on lately. Le Mutant and Half Nelson are working, so they'll make the trip.
Old 8th October 2011, 12:48 PM   #85
andyjevans is offline andyjevans  United Kingdom
I'm really interested in this thread and where it's going. I'm a tube guy and I can relate to this, though my ss knowledge is poor. I'm wondering about putting chokes in the power supply if there's a hum problem - tube technology! Also wondering about a tube front end with interstage.
I've been looking at Edcor transformers - they do 150, 300 and 600 ohm primaries. The Lundahl LL1627 could be used as well - that's a lot more expensive. Actually the Edcors are substantially larger than the UBT1 and Lundahl, which both weigh around 2.5 kilos. The Edcors are more like 4.5 kilos and rated for 400ma. I imagine there's a delay to get them of over a month, but still interesting and cheap too.
Andy
Old 8th October 2011, 05:16 PM   #86
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I think the 150 ohm would work. Of course you get all the usual limitations of
transformers on the bottom and top end.
Old 8th October 2011, 10:46 PM   #87
wrenchone's Avatar
I used the UBT-1s because I had them - no doubt better stuff could be had, as I consider the One-Electron stuff to be pretty much MOR. I might expect better things from the Triode Electronics monsters I have on hand, though their bias current capability is not that much higher than the UBT-1 (225 vs 160 ma). The reason I also tried this was that people jumped on to this suggestion when I made it in another thread and claimed that the bias current capability of the UBT-1s would be nowhere near the 085's sweet spot. I want to find out how much that matters. So far I've been pleased with the results. I only wish I'd had time to exorcise the hum issue so I could have brought the amp to BA this year. Experiments with higher bias current might prove interesting. I didn't want to deal with the extra 200 dollars and the wait time.
Any experiments with low or high bias current levels are limited by the power dissipation capability of the 085. It's in a TO-247 package (a good thing), but because of the small SiC die, the junction-to-case thermal resistance is pretty high, much more so than something more proletarian like an IRFP240. The SiC die itself can tolerate high temperatures, but the packaging material, the mount down, and adjacent components are another matter. This would have been a more usable part in a TO-3 package or one of those funky MIL-style metal deals. A company in New Jersey (United Silicon Carbide or something like that) has a data sheet out on a part looking a lot like the 085 (down to the funky gate leakage), but has it in a MIL-style package with glass to metal seals. I'm pushing ~45 watts through my 085s, using aluminum oxide washers (for both voltage standoff and thermal conductivity), and crossing my fingers. As soon as I can get off my butt long enough to lay my hands on some Arctic Silver, I'll be using that, too.
As for transformer limitations on low and high end, folks have been dealing with that in tube amps for decades with audibly satisfactory results.The brief here is semis in a tube-type circuit, how's it sound? Other games without transformers can be played at a later date. The circuit I'm trying also uses just one 085 per channel and doesn't require any byzantine matching games, a distinct plus when you're trying to suss out an unfamiliar and hideously expensive part.
I have a layout going that uses the IXYS depletion mode mosfets in a setup similar to what Nelson used in his First Watt 085 amp. An extra minus supply is needed so that the direct-coupled input circuitry works right with the small bias voltage required by the Ixys devices, but I'm cool with that. When I play with the actual circuitry and get some sensible results I'll post yet another thread.
Old 9th October 2011, 01:49 AM   #88
wrenchone's Avatar
Attached is a picture of the beast in question - not too big, but with 3 transformers, almost as ponderous as the Dutchy whale. I'll be looking for that hum tomorrow (tonight I'm relaxing by drilling and threading a bunch of holes on the Mutant's new heat sink). I have a capacitance multiplier on each amp module, but if those aren't working right, ripple would sneak through. Hanging a scope probe on the B+ will give me an answer for that in an instant. The transformer I'm using is split bobbin and kinda undersized for its 160VA rating - it may spray flux like a tom cat.
Old 9th October 2011, 01:59 AM   #89
wrenchone's Avatar
Attached is a picture of the two options I have for power transformers for the Puppy. The one I'm using currently is on the right. It's supposedly rated for 160VA, but feels kinda undersized. It also has a split bobbin, which is nice for primary-secondary isolation, but also increases the leakage/stray-spray flux. The transformer on the left is ~250VA, but weighs around twice as much - I trust it a little more, but it weighs a ton. It has a shield, and the end bells should help to contain stray flux. Grounding the core would also help. I had a bid in for an Antek 400VA toroidal isolation XFMR (no longer available from Antek), but I was inattentive and the end of the auction slipped by me.... I may gin up an SMPS for this guy if I get sufficiently frustrated with conventional iron.
Old 10th October 2011, 06:37 AM   #90
wrenchone's Avatar
I had a look at the B+ supply, and the capacitance multiplier doesn't appear to be doing much to calm down the line frequency ripple. Should be straightforward to fix - maybe I'll have a hum-free puppy by the end of the week.
"SiC Puppy SE Amp Using Semisouth 085 JFETHide this!Advertise here!
Semisouth SiC JFETs: SJEP120R100 or SJEP170R550 better for building amp? zhoufang Pass Labs 33 16th March 2015 10:56 AM
SemiSouth SiC JFET from $16/pc, shipping NOW! zhoufang Vendor's Bazaar 42 24th July 2012 06:11 AM
SemiSouth SiC Power JFETs RocketScientist Solid State 105 19th February 2012 08:02 PM
new SemiSouth SJDP120R085 "normally on" JFET zhoufang Pass Labs 11 8th June 2010 04:41 AM
