"SiC Puppy SE Amp Using Semisouth 085 JFET
Old 10th August 2011, 08:55 PM   #61
buzzforb is offline buzzforb  United States
buzzforb's Avatar
wrenchone,
How does the sound compare to a standard sand amp? Does running the fet at higher voltages change the sonic signature any. I know this is a difficulkt question, especially considering that your amp has an OPT.
Old 10th August 2011, 09:00 PM   #62
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Originally Posted by wrenchone View Post
it is the One Electron UBT-1
Q: Why do electrons all have exactly the same charge?
A: Because there is only one.
Old 10th August 2011, 11:29 PM   #63
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Q: .
A: yes
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th August 2011, 11:34 PM   #64
wrenchone is offline wrenchone  United States
wrenchone's Avatar
Buzzforb - using any more voltage on the B+ is a waste, as I'm right at the comfortable (actually, not very comfortable) limit for dissipation in a single TO-247 device, about 45W. I don't want to reduce the bias current to accomodate higher input voltage. If I did anything, I would reduce B+, increase bias current, and use a transformer with lower primary impedance (hotter turns ratio - more output voltage for a given input voltage). I have a Triode Electronics transformer that might just fill the bill, but I'm not going that route for quite a while.
This design was an exercise in adapting a standard tube amp topology for semiconductors, and I explicitely designed the circuit to utilize output transformers I already had on hand, hence the 300V B+ and 150 ma bias current, which is right near the maximum current rating for the One Electron UBT-1 transformer, also right at the limit for dissipation in a single TO-247 package. I opted to go for comparatively low voltage and relatively high bias current, as I judged that to be closer to the "sweet spot" of the Semisouth part. You could use higher voltage, lower bias current, and a higher impedance/turns ratio transformer, but that may not be optimum usage. I won't be doing a whole lot of messing around with those kinds of combinations, as it is both an expensive and time consuming exercise. An alternate approach using lower voltage, higher current, and a special output transformer is the "Nemesis", detailed elsewhere in this forum.
The project at present has proceeded far enough so that I have gotten two prototype channels to run with a bench supply. Sonic results from that setup were encouraging enough so that I want to box the amp wth a real power supply and a fan for extended listening tests with better audio components than were available in the lab. This will also allow me to do some measurements in a less noisy and life-threatening environment. This next step will take a while, as I haven't had a chance to search for an appropriate case, or figure out an alternate packaging aproach that won't take too much time and won't end up looking like Sh**. This design is also being time-division multiplexed with about six others, a full time job, a college radio DJ gig, and basic life maintainance functions. I will describe progress as it happens. If anyone else wants to forge ahead on a similar front and scoop me, be my guest.
Old 10th August 2011, 11:51 PM   #65
buzzforb's Avatar
I appreciate the answer. I wasn't inquiring about the possibilty of more voltage, just wondering how it would compare sonically to the same transistor with 80V supply and 2A of bias. AS you said, these devices allow us to run them as if they were tubes and it would be interesting if its the operating points that determine the "tubey" sound. I know this is a long shot and maybe even stupid, but interesting all the same.
Old 11th August 2011, 12:10 AM   #66
The one and only
The operating points, and thus the load-line, largely determine the
"tube-osity".
Old 11th August 2011, 01:21 AM   #67
wrenchone's Avatar
As I pointed out, there are people who are running the Semisouth devices with a lower B+ and much higher bias current (with a suitable transformer), though not necessarily the same topology. I wasnt aiming for any sound in particular, but wanted to see how the devices would perform given a set of design constraints. I liked the sound enough to proceed.
People who want to flap their ears at the end procuct can do so at the next Burning Amp.
Old 13th August 2011, 10:41 PM   #68
wrenchone's Avatar
I may take the SiC Puppy boards off the big heat sinks, pop them on to a 1/4" thick heat spreader, and use some attached microprocessor coolers to get rid of the heat - a smaller package, easier to handle.
Old 14th August 2011, 04:26 AM   #69
wrenchone's Avatar
On that front, I just scored home heat pipe-type coolers on the big Pay that may be up to the task of cooling both channels. The fan noise remains to be ascertained, but maybe I can afford to starve the fan voltage to reduce the noise level. The whole assembly will be inside a case, which should also help.
Old 14th August 2011, 05:32 AM   #70
VladimirK is offline VladimirK  Uzbekistan
"tube-osity".
Nice term, Nelson, I would also add, for widening a picture, that "tube-osity" will depend also on Ciss and Crss, their magnitude and variation with Vds. When we will approach to Ciss=10pF and Crss=1pF with "stone" parts, tubes for sure will be trashed.
"SiC Puppy SE Amp Using Semisouth 085 JFETHide this!Advertise here!
Semisouth SiC JFETs: SJEP120R100 or SJEP170R550 better for building amp? zhoufang Pass Labs 33 16th March 2015 10:56 AM
SemiSouth SiC JFET from $16/pc, shipping NOW! zhoufang Vendor's Bazaar 42 24th July 2012 06:11 AM
SemiSouth SiC Power JFETs RocketScientist Solid State 105 19th February 2012 08:02 PM
new SemiSouth SJDP120R085 "normally on" JFET zhoufang Pass Labs 11 8th June 2010 04:41 AM
