Dear Mr Pass,
first of all I would like to thank you for your formidable instrument. It makes great music. For the moment I use a XA100.5 with a pair of WA Sasha and I would like to combine the XA100.5 with a ARC Ref5. I would need your point of view on the technical side. My question comes from a reflection : " the input impedance of the XA160.5 is 30/20 Kohms (Bal/SE) and while the nominal impedance output of the Ref 5 is 600/300 ohms (Bal/SE), if it's like the Ref 3 it's output impedance gets close to 1.7Kohms somewhere in the 100-200Hz range I believe, so if the partnering amp is not of sufficiently high input impedance the match up tends to sound bass shy/thin." So as I'm not a specialist, would it be possible to know if you see any technical conflict or problems if I associate the XA100.5 and REF5? Many thanks for your help. Jean-Paul |
#2 |
The one and only
Our experience is no problems at all with the ARC or CJ products with
regard to interface. The amp doesn't care about source impedance. It's actual input impedance is close to 0 ohms, and the input impedance spec comes from the resistors we put in series with that input. Adding a little more from the source doesn't create issues.
#3 |
Many thanks for your answer, I will give you a feedback about the association. I'll try to make a comparison with your new preamp XP30. Can you describe us a little this new preamp and what we can hope from it compared with the XP20?
#4 |
From customer #1 who has an XP20 "blackness, depth, cohesiveness, resolution and dynamics the XP-30 is STUNNING!"
Just one opinion but it is a step up. |
#5 |
Hi Nelson, I was wondering whether the XA or X-series amps would be the best match with the Maggie 3.7? Would the XA100.5 monos have enough power to make the 3.7s sing? Magnepan Magneplanar MG3.6/R loudspeaker Measurements | Stereophile.com
Your input would be highly appreciated. Regards, Hasse |
#6 |
The one and only
Personally I always go with XA's. Some people want more output wattage
within a price tag, so the X series remains popular.
| A question for Nelson Pass | gaetan8888 | Pass Labs | 1 | 17th August 2010 09:57 PM |
| Question for Nelson Pass | Addicted Help!! | Pass Labs | 16 | 26th April 2007 06:12 PM |
| Pass X250.5 question for Nelson | georgehifi | Pass Labs | 4 | 15th March 2005 07:37 PM |
| Question for Nelson Pass | thylantyr | Pass Labs | 6 | 7th April 2003 03:17 PM |
| Nelson Pass; Thanks, and a quick question please! | mg16 | Pass Labs | 1 | 6th December 2001 06:09 PM |
| Page generated in 0.09062 seconds (77.31% PHP - 22.69% MySQL) with 10 queries |
