Old 4th July 2011, 09:14 AM   #1
Default Preferred JFET in Constant current source?
Hello all,
From all the wisdom and experience built up over time, is there a preferred JFET to use as a constant current source for say 3-10mA?
What about if the CCS is cascoded, does it mean the CCS quality (sound, PSRR, etc) is less dependant on the JFET?
Old 4th July 2011, 01:18 PM   #2
triode_al's Avatar
Personally, I like the 2SJ170, this little one will cover the whole range.
I have e.g. used it as a CCS for a phase inverter (6SL7); as well as a tube bias for a cascoded 6SN7/ECC82 CCS.
The 2SK170-CCS in a simple form is a little dependent on voltage (say 3-50 volt), which does show up on the work bench, specifically for the higher currents. That said, this is the converted resistance. But that is true of the majority of simple forms.
As well this FET is temperature sensitive; even the 2SK30 is to some extent (which I prefer for the low currents).
I have made complex CCS's (with small mosfets; led gate voltage) but that does make sense only if enough 'headroom' is available, plus the auxiliary current for the CCS bias. Swinging from 5 to 50 volt will even then show a minor increase of current.
See my 2SK175/2SJ55 F5.. CS8412/SAA7220/TDA1541 ; SP-6 Light ; MC30 Super--> two stage RIAA 2SK240-ECC88/6SL7.
Old 4th July 2011, 03:48 PM   #3
if low volts drop across the CCS is not a priority then avoid the expensive k170.
There are lots of much cheaper and more easily available jFETs. bf862, bf244/5, 2n5457/8/9, 2n5460/1/2,
Read Walt Jung on CCSs. He tells us that min Vdrop must be >=2*Vp. This is important.
A lower Idss jFET will have a lower Vp than a higher Idss from the same family. If you need exceptionally low Vdrop then a 2sk170gr is hard to beat.
regards Andrew T.
Old 4th July 2011, 05:51 PM   #4
THanks guys
Old 11th July 2011, 05:39 AM   #5
I have seen BF256 and BF245 used in Elektor designs.
Sam
Old 11th July 2011, 06:45 AM   #6
h_a is offline h_a  Europe
h_a's Avatar
Ideally you would like to use a high input impedance jfet for a constant current source, so a 2SK246 is prefered over the 2SK170. It is, however, a large pinch-off voltage jfet, so voltage drop is larger.
If one's interested in further reading, Erno Borbely discussed this issue nicely.
Hannes
Old 11th July 2011, 01:56 PM   #7
Can you provide a Borbely document title?
Old 11th July 2011, 06:58 PM   #8
h_a's Avatar
jeez, sorry I just had a look at Borbely's Jfet-the new frontier articles and these do not exactly contain what I meant.
I think I (correctly ) remember now it was Walt Jung. Sorry for that, but I'll try to dig out a reference. Don't mind reminding me for that as I'm pretty busy currently.
Hannes
Old 11th July 2011, 07:48 PM   #9
jcx is offline jcx  United States
Default "long channel" geometry jfets best for ccs
http://liveweb.archive.org/http://ww...0596/70596.pdf
those intersted will probably want all of the Siliconix app notes: JFETs Application notes
Old 11th July 2011, 10:26 PM   #10
thanks Jcx
regards Andrew T.
Why is it not a Constant Current Source ? payloadde Power Supplies 3 17th April 2011 09:59 PM
Constant current source, am I missing anything... gmphadte Power Supplies 4 3rd August 2007 04:07 AM
constant current source hacknet Solid State 19 13th March 2006 02:46 PM
Constant Current Source A/B Test EchoWars Solid State 20 14th March 2003 12:49 AM
Aleph Constant Current Source RobPhill33 Pass Labs 2 20th February 2003 02:54 AM
Page generated in 0.10347 seconds (80.05% PHP - 19.95% MySQL) with 10 queries
