Tricky little problem with Z4 component
Old 19th August 2003, 03:14 PM   #1
Buhl is offline Buhl  Denmark
Buhl's Avatar
Default Tricky little problem with Z4 component
Hi there !
This is a little embarressing, but when i ordered the parts for my dual bridged Z4, i couldent get fixed value 5 pF capacitors, so i ordered variable 5-15 pF. Fine enough, but how do I check i witch of the outer positions (the lowest 5 pF one) those trimmers has to be in ?
I have no scope to measure the square wave as mentioned by
nelson in the article, only a "standard multimeter that can measure volts, amps, resistance and diode function.
Can I do this without a capacitance-meter ?
Cheers !
Hans Houmøller
Old 19th August 2003, 03:39 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Hans
You should definitely try to buy a scope.
As for the cap, only with a scope it will be possible to trim a square wave up to it's nicest shape.
You could also buy 2 10pf caps and solder them in series.
If you get some decent caps (silver mica) it will improve the sound as well. I'm not claiming I would hear the difference but a trimming cap is probably not the best sounding device to put in a feedback loop.
Without a scope, my guess is that it will be difficult to measure
the trimming position with such low values.
Maybe others know how to do this...
Greetings
/Hugo
Old 19th August 2003, 08:58 PM   #3
Buhl's Avatar
Originally posted by Netlist
Hans
Greetings
/Hugo
Thnx for the advice Hugo - Ill try and persuade someone with a scope to measure a squarewave for me. No harm will come to the amp or speaker though if operating for a short while in the 15 pF mode instead of 5 pF - just in the power-up period ?
Cheers !
Hans Houmøller
Old 20th August 2003, 07:37 PM   #4
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
This is not a critical thing. When I want 5 pF, I twist 2
pieces of wire wrap wire (the teflon insulated kind) together
for about an inch.
Old 21st August 2003, 01:15 AM   #5
eLarson is offline eLarson  United States
eLarson's Avatar
A teflon trimmer capacitor that anyone could afford! How cool is that?
Erik
Would a woodchuck bother to chuck MDF?
Old 21st August 2003, 03:10 PM   #6
Buhl's Avatar
Thanx for the replys, but I actually came across 4 pcs. of 5 pF at my local electronics shop, that normally have everything but the partsI need, but in this case - they had what I couldnt find on the web......
Another thing, I very soon about to fire up my Z4 - can i run two boards supply from the unregulated supply in parallel ? Simply connecting board two to the same supply + and - as board one ?
/cheers !
Hans Houmøller
Tricky little problem with Z4 componentHide this!Advertise here!
Tricky CA21REX question Daze Full Range 0 7th March 2008 07:16 PM
Tricky op-amp based VR problem matejS Power Supplies 22 29th August 2007 03:27 AM
A tricky question from a novice msharpe Multi-Way 14 28th May 2006 06:41 AM
Tricky MS Excel function Stocker The Lounge 5 9th August 2005 03:55 AM
