Old 18th August 2003, 04:29 AM   #1
Default Triac Question
Can they be paralled to handle more current ?
Thx, vinay
Old 18th August 2003, 04:37 AM   #2
JOE DIRT®'s Avatar
a Triac is for AC and the best route is to drive a relay through a opto-coupler (ex. Moc 3010)
you did not mention for what application
DIRT®
Old 18th August 2003, 12:07 PM   #3
djk is offline djk
djk's Avatar
"Can they be paralled to handle more current ?"
No, use inverse parallel SCRs of the needed current and run a MOC triac driver between the gates.
Motorola (ON Semiconductor) has an app note on this subject.
http://www.fairchildsemi.com/ds/MO/MOC3041-M.pdf
Same thing, Fig 14, 15
Old 18th August 2003, 12:13 PM   #4
Electrons are yellow and more is better!
peranders's Avatar
TRIAC's are rather cheap. I suggest you use one with the rating you need. 25 A costs in Sweden 3 USD a piece from a expensive place.
Avoid pararelling, without going into why.
/Per-Anders (my first name) or P-A as my friends call me
Old 18th August 2003, 03:59 PM   #5
Thanks for the responses.
I want to use it as the mains switch for my power amps.
Vinay
Old 18th August 2003, 04:17 PM   #6
peranders's Avatar
Note: The TRIAC introduces noise so you will need a main filter.
I suggest that you start with an ordinary relay. Switch to a triac if the lifetime of the relay is too short, even with necessary protection.
Old 18th August 2003, 07:09 PM   #7
The one and only
Nelson Pass's Avatar
Triacs introduce noise in the power line not only from the
action of the switching at high frequencies, but also a DC
component due to asymmetric switching. Users of Triacs to
switch the power into the primary of their power transformers,
particularly toroids, would be best advised to drive the triac
control pins hard to avoid the DC issue.
Old 26th August 2003, 12:57 PM   #8
Send a message via AIM to xenofex Send a message via Yahoo to xenofex
How to drive the control (gate) pins hard Currently I used a stud mount triac 2n6162 rated 600v 300amp for my Aleph 5, between the gate ( G ) and anode ( MT1 ) i've connected 2 thermo switch in series, I don't think this will put any load on the control pin. Thanks
Old 26th August 2003, 08:31 PM   #9
The one and only
By driving the control pin hard, I mean turning the Triac
on very early in the AC cycle so that there is as much symmetry
to the waveform as possible. Usually this means low resistance
in series with the control pin so that it turns on right away.
Need a Triac zedrider Parts 1 28th September 2007 03:38 PM
SCR or TRIAC? Wombat2 Parts 3 6th June 2006 03:21 AM
Triac regulator fr0st Parts 2 19th November 2004 06:15 AM
triac's used as crowbar?? hugobross Solid State 19 12th August 2002 04:02 PM
Page generated in 0.09133 seconds (76.81% PHP - 23.19% MySQL) with 10 queries
