Old 14th June 2011, 01:43 PM   #1
Default Fuse replacement for Threshold SA/10e
So I want to replace the fuse in the 10e. Any suggestions? Does Fuse affects sound quality? I did some researches, and seems most "audiophile" agrees Fuse will definitely make a difference.... comments?
Old 14th June 2011, 04:32 PM   #2
The one and only
Nelson Pass's Avatar
It has a lot to do with where the fuse is located. If it's in series with the
signal path at the output of the amplifier, then there is more potential for
problems, but if it's in the power supply, the effects are going to be less by
virtue of the PSRR, the power supply rejection ratio of the circuit, that is the
ability of the circuit to ignore noise and distortion in the supply.
The issues with a fuse are two-fold. First, there is a subtle modulation of the
resistance value of the fuse which could be a source of distortion. The higher
the value of the fuse, the less the effect, and the longer the time constant
of the fuse (slow-blow vs fast blow) also has an effect.
As you reduce the potential for modulation in a fuse, you reduce the
protection it offers.
Second, the quality of the connection between the fuse and fuse holder can
be a source of distortion if the contact surfaces are dirty or oxidized.
Old 15th June 2011, 03:40 AM   #3
Hello Mr. Pass, thank you fro the explanation. That is very well explained!
I am planning to replace all the Rail Fuses and AC Fuses on the amps, as they looked like poorly made, and are very old.
Threshold SA/2 SA/3 Soderburg site? johnsciolino Pass Labs 3 14th January 2012 06:31 AM
Threshold SA/ and SA/e series monoblocks gigi.vassallo Pass Labs 0 6th January 2010 07:07 PM
Threshold SA/4e and SA/2 Mywing Pass Labs 8 4th January 2010 10:45 PM
Threshold SA/1 standard fuses replacement and use of Variac BrianEno Pass Labs 5 28th November 2009 03:21 PM
Threshold FET 10e Manual hifi-hospital Solid State 3 12th April 2009 03:24 PM
Page generated in 0.07233 seconds (73.01% PHP - 26.99% MySQL) with 10 queries
