You'll need 3 of them and I suggest only using them for the midrange... - with some class AB SS for the woofers (chip amp a la gainclone, easy to build, or X-amp - not AX though), and Aleph 3/30 or Mini-A for the Tweeters...
I have a Linkwitz style dipole, fullrange from 310 Hz up (no tweeter). I just built some Mini-Alephs for the fullranges. That works fine, the ca. 25 W RMS is a-plenty. My woofers are now on one BB OPA549 per woofer (2 per channel, 4 in total), also plenty, drives them to more than cone excursion limits. Sound is tight and well controlled even though the mini-A has a less favorable output Z because only 1 output device.
After all in such bi/triamped systems you need less power per channel, so distortion will be less in Aleph topology as I understand, and you stay away some 2 octaves from Fs so damping factor should be less of an issue. Besides the Aleph2 distortion quoted surely represents a worst case figure into 4 Ohms.
The X-O: all you need to do is to add an IC unbal-> bal converter per output, such as 6 DRV134 or 3 DRV 2134 (double channel) total, from Burr Brown/Texas Instruments. Add this after the last buffer of each X-O channel, and without the R196 output resistors which will not be needed in this case.
