Old 9th June 2011, 08:21 AM   #1
oon_the_kid's Avatar
Default Mr Pass...Some crazy ideas for your new amplifier...
Dear Mr. Pass,
I have not build an amplifier of your s yet, but hopefully when my schedule clears up, I would very much like to try one.
However on a different note, the sound quality of the entire system still depends on the rest of the partnering components (DACs, volume control etc) irregardless of how well your amplifers are designed.
Since you also design IV converters why not just merge your IV converter and your amplifier into one. Make it a power DAC. Volume control can be implemented digitally on one of those 24 bit DSPs that upsample from 16 bit. I think there are a few out there. The output of a 24 bit sigma Delta DAC could then be fed directly into your amp (differential input). This could effectively mean the only thing that stands between your DAC chip and your speakers is only one transistor/FETs (or maybe 2).Can't think of anything more direct...
There would then be no ambiguity on how the rest of the components will affect the sound...
Oon
Old 9th June 2011, 05:31 PM   #2
The one and only
Nelson Pass's Avatar
Many of the suggestions I receive are in the form of how I can integrate
components together to form integrated amplifiers, amplifiers with crossovers
built in, power DACs, and so on.
However I am largely headed the other way, separating out power supplies,
output stages, and front end circuits into separate pieces so that they can
be mixed and matched at will. While it results in many more boxes, it
gives me a playing field to easily listen to the differences in component
sub-circuits and refine them while keeping other elements constant.
But then that's me. Someone else will likely be happy to integrate
components so as to make life easier for customers.
Old 9th June 2011, 06:08 PM   #3
osscar is offline osscar  Latvia
osscar's Avatar
I also like stand-alone components - preamps, dacs, passive preamps, RIAA, power amps with no knobs . and if its a Saturday morning - I started to change boxes depending on the mood
Old 9th June 2011, 06:42 PM   #4
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Perfecto .........
Old 10th June 2011, 12:57 AM   #5
DJNUBZ is offline DJNUBZ  United States
So I guess there will never be a chip amp F5 then huh. I was thinking that would be a cool idea just the other day. In an IC everything could be a perfect match.
Old 10th June 2011, 01:26 AM   #6
tinitus is online now tinitus  Europe
funny, the other day I thought about doing that
Old 10th June 2011, 01:58 AM   #7
Dear Mr. Pass,
I respectly accept your opinions. In a hypothetical state if you were to build such and amp how would you go about doing it (DAC+amp) all in one. What sort of approach would you use?
1) use a combination your Zen I/V converter and your Aleph J amp?
2) use a bipolar to directly amplify the current from your DAC and couple that with a current source?
What sort of approach do you think makes the most sense....
Oon
Old 10th June 2011, 02:02 AM   #8
sound more like a class-D Hypex active speaker concept
Old 10th June 2011, 03:01 AM   #9
6L6 is offline 6L6  United States
6L6's Avatar
I think that is an outstanding idea!
But how do you keep grounding (loops, etc..) from becoming an issue?
Old 10th June 2011, 03:13 AM   #10
not quite true, there is no PWM involved.... I think it would be closer to using a gainclone power amp chip for I/V conversion.
I just think it would be cool if by addition of a few transistor we could directly drive a speaker using your DAC...
Oon
Pass Labs amp combination for Thiel speakers, need Mr Pass' advice ! And everyone... JulienG Pass Labs 78 26th December 2010 06:29 PM
Paging Mr. Pass, Mr. Pass pull my finger please. khundude Pass Labs 2 5th December 2008 04:11 AM
Crazy studio monitor ideas. holger honda Multi-Way 9 16th January 2005 05:11 PM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
My amplifier ideas (crazy) Duo Solid State 38 27th June 2002 09:32 AM
Page generated in 0.10439 seconds (83.16% PHP - 16.84% MySQL) with 11 queries
