SS 120R085 Depletion Mode Jfet
Old 14th July 2012, 03:15 AM   #241
flg is offline flg  United States
flg's Avatar
Well, the relavince to Micheals 1st article and SITs in general is very much the same. If you do the load line thing thru the R085 graph buzzforb made, you see a nice low distortion loadline! I extrapolated a little bit and set an operating point at 2.5A and 16V. I'm not sure 8 ohms dosent look the best. Just playin with graphs though
Hmmm
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 14th July 2012, 11:31 AM   #242
buzzforb is offline buzzforb  United States
buzzforb's Avatar
FLG,
Here is a link to a negative voltage generator Nelson suggested.
RO85 Zen
I may try to test the fets lie MR suggested in the article to see if we can get the voltages up a little.
...Shape the sound , Man!
Old 16th July 2012, 11:00 AM   #243
buzzforb's Avatar
Got mine up and running yesterday. Sounded good enough that i want to cean everything up and get test rig worked out. Iam finishing up the GB, so it is goingt o haev to go on the back burner for a couple of weeks while i get everything sorted.
Old 16th July 2012, 12:27 PM   #244
flg's Avatar
Well, I played with your graph quite a bit and settled on an operating point about 15V and 3A That's 45W dissapation!
Maybe go for a 5-6 ohm loadline for starters? Very similar to what MR did with the SITs
Old 16th July 2012, 12:54 PM   #245
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
what's wrong with 45W diss ?
Babelfish J is burnin' 50W in each IRFP150N with ease and only thing sweating is my forehead
...... make my day , punk ........
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 16th July 2012, 01:45 PM   #246
flg's Avatar
The IRFP150N is rated at 160W max dissapation. The R085 114W max dissapation. You are running about 31% of max dissapation. My intial q point would be almost 40% of max dissapation. The max Thetaj for the 150 is .95C/W the R085 1.1C/W
Your sweating
Old 16th July 2012, 02:49 PM   #247
buzzforb's Avatar
Based on Nelson's articles, I think 45W is ok. Mine seemed Ok, even if on oversized heatsink. Nelson often speaks of the tendency of Toshiba parts to be able to go beyond specs. I assuming the same here. PLus, I have a nice and quiet desktop fan that can do amazing things to hot amps. What is your rail voltage? I plan on presenting both SE and SRPP version with measurents to boot, as I tihnk this is going to be worthwhile. THe SE version sounded nice to my ears.
Old 16th July 2012, 04:27 PM   #248
flg's Avatar
Of coarse, the V+ will depend on the speaker and Rl (the effective load) of the gain device. With a 8 ohm speaker and a 14 ohm load R, I would see about a 5 ohm LL with 57V V+. deffinatly something that needs to be experimented and played around with a little...
Old 17th July 2012, 12:56 AM   #249
Melon Head is offline Melon Head  Australia
Banned
Hey Buzz. Why not do some destructive testing. It would be very informative. Try running ond at 100W continuos and see how long it lasts for. Make sure you also record the temperature
Old 17th July 2012, 01:13 AM   #250
buzzforb's Avatar
30$ per fet gets expensive, although i do Sh^t that much out on occasions
SS 120R085 Depletion Mode JfetHide this!Advertise here!
Depletion mode mosfets for 2mA CCS ? mach1 Tubes / Valves 6 29th October 2008 08:50 PM
Depletion mode? CBS240 Solid State 1 4th October 2007 08:52 PM
depletion mode mosfet selection svokke Solid State 0 17th May 2004 08:47 PM
How's about a Depletion Mode / Enhancement Mode CCCS MIKET Tubes / Valves 9 11th September 2003 03:44 PM
