SS 120R085 Depletion Mode Jfet
Old 12th July 2012, 10:06 PM   #231
flg is offline flg  United States
flg's Avatar
Well, I've been digestiing some of that... Looks very much like the operation I think we are interested in... I even took it upon myself to sketch some extrpolated lines further out...
I think it is interesting that the graph buzzforb is producing is the area below the graph in the data sheet. (Great work there buzz) The data sheet does not show this "triode" like behaviour!
So, can we find some ideal operating point in there somewhere? I have 2 parts and a doner Heat Sink, I suppose I can find 2 50W 1 ohm's
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 12th July 2012, 11:02 PM   #232
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I think I am going to try pure SE first, then move to SRPP. To me, the graph looks a little like the Sit graph. Gonna try with triple 22R 50W as Rd. No Rs and fixed bias. Rails will be a measly 27V. Gonna see if i can locate sweet spot for this particular device and then move to SRPP. Starting with -4.9V Vgsand about 1.8A. Moving slow and trying to learn.
...Shape the sound , Man!
Old 12th July 2012, 11:04 PM   #233
buzzforb's Avatar
FLG,
I dont know what it is, bu ti believe there is some significance to the ratio of the dual resistors.
Old 13th July 2012, 12:45 AM   #234
flg's Avatar
Well, note the ratio in the Amp Camp Amp! And, remember reading that we should set up a string of .1 ohm Rs and tap off where we like it from N.P. Probably the J2 thread.
Kinda like P3 I believe
Old 13th July 2012, 12:59 AM   #235
buzzforb's Avatar
Exactly! The resistor string is from this thread. Steven recommended .1 ohm lower on top resistor...just like amp camp amp. Never thought of it that way, but the P3 analogy is perfect. THanks. Let me know if you want other measurements. Gonna set the curve tracer up to do 4A, but it reduces available voltage. Did you see the last measurement. Greater voltage makes a significant difference in the positioning of the curves. From the couple i have tried, 4.8-5.3 seems to be a nice starting spot. Little comparison for ya.
Old 13th July 2012, 01:43 AM   #236
flg's Avatar
I beleive the shifting of the output point, from top to bottom of the 2 ohm string, will actually make more or less current source or push-pull output. Analagus also to the gain adjustment of the Aleph current source and the pot in the PLH. I think he said we would like a choice or something.
Old 13th July 2012, 02:03 AM   #237
flg's Avatar
Yes the last measurements still didn't quite get what I was totally wanting to see though, but, it still looks good. Somehow, I can't beleive you're the first to find this? And like I said, it was right under our nose's, just not in the data sheet.
I notice some reasons for apprehension though. For instance, we brave Diy'ers probably want to run this thing at 35-45W dissapation. I don't know if that's such a good idea. I know about the reputation of SiC and all. The plastic package will probably survive some rediculous heat for a while too. But it kinda looks like this is a small die in a big package. Something we usually want but don't get but, in this case, that might mean 25W max dissapation? the theta j only spec'ed at max 1.1 C/W isn't impressive either.
Also, if you want to self bias, the 2 ohm thing might be a killer???
Old 14th July 2012, 01:53 AM   #238
flg's Avatar
I haven't thought it all thru yet but, can we find more than a gain of 2.5-3 goin on here? That could be an issue I thought a bit better than that... Hmmm...
Old 14th July 2012, 02:15 AM   #239
buzzforb's Avatar
This is where i get lost as well. Then again, not so different from Sit graph above.That is the main reason I am trying simple resistor loaded version first. I can measure gain rather directly that way and then see how SRPP compares. I have also thought of cascode on top but seems like a waist. Nelson had the DeLite biased pretty high, 80V-1.8A. I know bulb dropped a lot, but still should be pretty wamr area of operation. Nemesis article he seemed to suggest 40W. I will have mine finished tomorrow, hopefully. I remember Broskie calling the SRPP an impedance multiplier. Wonder what impedance it multiplies? Oh well. Tomorrow.
Old 14th July 2012, 02:34 AM   #240
buzzforb's Avatar
Check out post 203 and 204
SS 120R085 Depletion Mode JfetHide this!Advertise here!
Depletion mode mosfets for 2mA CCS ? mach1 Tubes / Valves 6 29th October 2008 08:50 PM
Depletion mode? CBS240 Solid State 1 4th October 2007 08:52 PM
depletion mode mosfet selection svokke Solid State 0 17th May 2004 08:47 PM
How's about a Depletion Mode / Enhancement Mode CCCS MIKET Tubes / Valves 9 11th September 2003 03:44 PM
