SS 120R085 Depletion Mode Jfet - Page 21 - diyAudio
Old 27th May 2012, 04:07 PM   #201
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally Posted by buzzforb View Post
Diy curve tracer psu. Need 36V+ and about 5A of clean power. I could do big clc, but didnt know if that was adequate as i think the needs for big Class A power amp are not as great in comparison to digital baseed stuff.
basic know how
LM317 PASS TRANSISTOR REGULATOR - Electronic Circuit and Kit - freecircuit.net
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 27th May 2012, 04:13 PM   #202
buzzforb's Avatar
Originally Posted by StevenOH View Post
And if you have to stay with SJDP only, you just combine the two sketches
I have posted into one attached.
The new negative voltage reference will set both JFets to the selected current bias, pot in the voltage divider will set the output node to the ~half of the supply voltage. Just find the lowest value for R2, that will work for
your speakers and your ears (again, it's a balancing act). Here R4 will be tens KOhm.
So we have come full circle with some nice changes. We have traded self bias for fixed and added feedback to improve Zout. Nice. Is the top biasing mechanism, consisting of V divider and cap, referred to as a gyrator. Ratio of R6/R5 set gain, correct.
...Shape the sound , Man!
Old 27th May 2012, 05:42 PM   #203
StevenOH's Avatar
<<Is the top biasing mechanism, consisting of V divider and cap, referred to as a gyrator?>>
No. C2, 300 ”F is just a coupling capacitor, and, as demonstrated, is not unavoidable. Gyrators, generally, convert impedances - one into another.
The name of this whole arrangement is SRPP.
<<Ratio of R6/R5 set gain, correct?>>
Not exactly. Since the OL gain here (2ŚRload / R2) is not high enough to sacrifice for the FB, I suggested to increase it at the expense of some other parameters by reducing R2. So, for the CL volt gain of let's say 15, that ratio may be ~30.
Besides, R5 will be acting together with C1 and Signal source impedance in series. This is why I stressed the requirement for C1 value. And I have to remind you, that to drive that high and nonlinear Cin of power FETs you will need pretty low source Rout with good output current capability.
The truth is out there. Who can handle the truth?
Old 27th May 2012, 06:20 PM   #204
StevenOH's Avatar
The last paragraph in this post:
L'Amp: A simple SIT Amp
is a good illustration to what I have said here.
Old 27th May 2012, 07:04 PM   #205
buzzforb's Avatar
Does this seem to be a reasonable and accurate description of what is going on?
http://valvewizard2.webs.com/SRPP_Blencowe.pdf
It suggest that the when attached to a load, the top fet is in parallel with the load.
Old 27th May 2012, 07:19 PM   #206
Zen Mod's Avatar
it always is
just imagine that top one as CCS
then imagine that that CCS can be modulated to our liking
and it is - by AC going through drain resistor of lower one
Old 27th May 2012, 07:25 PM   #207
buzzforb's Avatar
So much pressure toget this right now. I love it. Feelslike i am back in school,but school is fun this time. Thank youboth,very much. I nned to go delete my sudscription to blowtorch thread. Instead of brilliant men advancing audio, universal ******* contest.
Old 30th May 2012, 12:57 AM   #208
buzzforb's Avatar
Waht do yo think? Pay no attention to funny things with Rs. Not even going to be used. Working of old schematic. Just realized I dont have pull down R in front of cap. Will add.
Old 5th June 2012, 01:16 PM   #209
buzzforb's Avatar
Here is update based on Steven' Recommendations. I have jumpers that will allow me to try self bias DC coupled version as well. Maight as well try both ways.
Old 3rd July 2012, 10:27 AM   #210
buzzforb's Avatar
I redid the boards and etched them last night. I have a question about the Rs for the lower fet. Sy is a big fan of LED bias in some of his tube stages. I believe he says that they were tested and found to be quieter than reistors in terms of noise and offer other advantages, such as lower AC impedance. While an LED is not possible at these bias levels, It might be an iteresting experiment. I caould do mulitple, but the number would be too great. This got me thinking about the diodes from the F5. In theory, thewre should be little difference in the two, with the main difference probably being Vf and AC impedance. The diodes from the the F5T, have a larger Vf than I was looking to use, but there are some failry inexpensice schottky diodes with lower numbers. What do you think of the idea and how do i test the AC impedance of one of them.
Depletion mode mosfets for 2mA CCS ? mach1 Tubes / Valves 6 29th October 2008 08:50 PM
Depletion mode? CBS240 Solid State 1 4th October 2007 08:52 PM
depletion mode mosfet selection svokke Solid State 0 17th May 2004 08:47 PM
How's about a Depletion Mode / Enhancement Mode CCCS MIKET Tubes / Valves 9 11th September 2003 03:44 PM
Copyright ©1999-2017 diyAudio
