SS 120R085 Depletion Mode Jfet
Old 25th May 2012, 10:48 PM   #181
buzzforb is offline buzzforb  United States
buzzforb's Avatar
You mean in line with cap to top fet.
...Shape the sound , Man!
Old 25th May 2012, 11:20 PM   #182
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
something in line with this : L'Amp: A simple SIT Amp
I'm not saying all values are adequate for your cause , but what's important is principle
I don't have depletions , so I can't help more , except with dry datasheet based conclusions
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 25th May 2012, 11:48 PM   #183
buzzforb's Avatar
Thanks. Downloaded that as well as another one of his schematics. Gonna build it even if its wrong. Always learn more from mistakes anyway. Hardheaded like that.
Old 26th May 2012, 12:03 AM   #184
Zen Mod's Avatar
Originally Posted by buzzforb View Post
........ Hardheaded .........
welcome to the club
Old 26th May 2012, 01:05 AM   #185
StevenOH is offline StevenOH  United States
StevenOH's Avatar
Buzzforb,
Your pic was supposed to look like smth attached. SRPP.
In this case top tr do not need to be of depl type, ench SJEP will be
equally good.
But remember, that this circuit with SemiSouthes will have high output impedance =current drive. And you will not achieve muF with this vertical positioning of one on top of the other - only if you "disassemble" the pair.
Those SS will require volt FB to have sufficiently low output imp.
Smth along the lines of post by Knutn -also attached.
The truth is out there. Who can handle the truth?
Old 26th May 2012, 11:10 AM   #186
buzzforb's Avatar
Thanks Steven. Why does the top resistor need to be .9 vs 1R? Isn't this the bias setting resistor for the top fet? If i take the signal from above this resistor, do I have a Mu Follower? I must admit that I do not understand the "disassemble" part, but that is not shocking. I guess feedback and output impedance are a reason Nelson uses the LTP input in his FW amps, although i thought that Zout would be reasonable. I am going to measure curves for the R085 and start doing some actual math today. May also consider using FQA up top as it has higher Yfs than R085 and that should help with Zout, correct?
One more thing. The reason I used a voltage divider on the R085, is that Nelson had stated in other threads that stability of the bias of the upper fet was problematic, even with depletion devices. This was not a direct comment from him, but extrapolated from what was stated about smaller Jfet cousins, like sk170.
Old 26th May 2012, 11:23 AM   #187
Zen Mod's Avatar
as I wrote few times - try to find (buy , steal , borrow ) book called How to gain gain_A Reference Book on Triodes in Audio Pre-Amps
interesting reading , back to the roots and up to the sky
goooogl is your friend
then you'll learn difference between mu, srpp etc.
for output impedance of mu follower , ratio of these two resistor in totem is dominant - over xconductance , of used part
Old 26th May 2012, 11:27 AM   #188
buzzforb's Avatar
Will do. Been reading up on SRPP and Mu follower, but most just touch on differences without much explanation.
Old 26th May 2012, 11:30 AM   #189
Zen Mod's Avatar
output signal point
witty Pa made bazztardo in some of his (known ) amps - modulation (of upper element) from one point , output signal takeover from other point
Old 26th May 2012, 11:36 AM   #190
buzzforb's Avatar
It seems i have much to read and do this weekend. Beats typing
SS 120R085 Depletion Mode JfetHide this!Advertise here!
Depletion mode mosfets for 2mA CCS ? mach1 Tubes / Valves 6 29th October 2008 08:50 PM
Depletion mode? CBS240 Solid State 1 4th October 2007 08:52 PM
depletion mode mosfet selection svokke Solid State 0 17th May 2004 08:47 PM
How's about a Depletion Mode / Enhancement Mode CCCS MIKET Tubes / Valves 9 11th September 2003 03:44 PM
