Weird F5 bias issue
Weird F5 bias issue
Old 25th June 2011, 04:37 AM   #21
JZatopa is offline JZatopa  United States
So 0 offset > then bias V. OK sounds good to me.
Old 25th March 2015, 04:36 PM   #22
Rewind is offline Rewind  Sweden
Rewind's Avatar
Good thread. I got some similar problem with cviller v3.0 F-5 non-turbo boards. Might just replace the jfets with the recommended values. Now I tried 12.5 mA LS74 and 9.22mA 2sk170. I made a short on the channel that is acting up due to a bad DMM. Just a short flash, but might have been enough. I get 0.5V offset at 0.5V bias across the closest 0.47R 3W resistor. Input closed, speaker outputs open. The other channel has 0.23V with 0.6V bias.
Weird F5 bias issueHide this!Advertise here!
Weird issue with tube driver. 807tubenut Tubes / Valves 17 15th September 2010 01:19 AM
f5 power up issue specialidiot Pass Labs 54 2nd May 2010 12:27 PM
Sundown SAE-1200Dv1 Weird output issue possible Fet problem? RosDaddy Car Audio 7 11th April 2010 03:12 AM
Weird Bias on Simple SE ixe13 Tubelab 12 9th July 2009 10:53 PM
Weird soundcard issue JacquesK Multi-Way 1 19th May 2008 07:07 AM
