Old 6th June 2011, 12:08 PM   #1
tiefbassuebertr's Avatar
Default Reference Audio Amplifier without BjT's,jFET's and MOSFET's SpecialMadeForAudio wante
Most high end audio companies and authors for diy projects prefer the use of typical audio frequency (AF) transistors like 2SK389, 2SK170 and 2SJ74 for the input stages, BF469-BF471 for the VAS stages and 2SA1943/2SC5200 resp. 2SK1530/2SJ201 for the buffer stages.
About the URLs
Audio (Lateral) MOSFET's for Class AB - Overview, P-Spice URL's
Transistor data with sorting
bipolar (bjt) transistor families for audio power output stages
High Voltage BjT's for Pre-driver stages of High Power Amplifier - Overview
you will find some overviews about this kind of transistors.
I guess, in a short time all this types will be more and more obsolete.
Therefore I am looking to amplifier topologies suited for currently and in the near feature good available transistor types from the aera "recommend for Switching applications" but not from the area "recommend for audio applications".
A good known older example of such an amplifier was the allfet amps from the "Aleph" series, equipped with International Rectifier MOSFETs, also in the input differential amp.
After I have heard amps from the "Aleph" series, I wonder, why many complain, that typical audio transistors disappear from the market or are offered only as a copy of other manufacturers from India. Seen such typical audio transistors have really no reason to exist under these conditions.
On the other hand - until this day there are not much other comparable amplifier without semiconductors "Special Made For Audio" (except Class-D like UcD), particularly as commercial products and additional also as diy projects.
Appropriate topologies, mentioned here on diyaudio probably are the follow:
It's cheap, it's N, it's dirty, it's.... The CIRCLOMOS!!!
♫♪ My little cheap Circlophone© ♫♪
and the overview
URL collection of Totem Pole and CSPP (Single Ended related) Solid State Output Stage
I am looking forward to find more such amp topologies in the near future.
Old 9th June 2011, 09:07 AM   #2
h_a is offline h_a  Europe
h_a's Avatar
No need for special topologies, all amps work also with 'normal' transistors as long as the requirements are met.
Audio transistors usually have 'only' particular linear hfe (BJT) or constant capacitances (Mosfet) which might in some cases lower distortion a bit.
Hannes
Old 9th June 2011, 02:22 PM   #3
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by tiefbassuebertr View Post
the "Aleph" series
Back when the first commercial Aleph power amp came out, the O (or Null, whatever), it was regarded as somewhat of an oddity at first.
Not Class AB, not regular P-P Class A, but primarily single-ended, and with a constant power consumption figure that even die-hard Class A lovers found a tad over the top.
The Aleph was phrased as an amp for the sporadic aficionado, which still is valid today.
The typical "high-end" Japanese parts are/were aimed at main stream audio.
It's also pretty BJT components which are dissapearing, think A1349/C3381, think MAT02/03 and the likes.
Looks like Sponge Bob has killed another thread.
Audio (Lateral) MOSFET's for Class AB - Overview, P-Spice URL's tiefbassuebertr Solid State 46 13th May 2012 09:50 PM
GX400 - 400W Audio Amplifier - Made in Romania donpetru Solid State 10 16th March 2012 11:14 AM
FS: Golden Tube Audio SE-300B II Special Edition Valve Amplifier coh-b-pyky Swap Meet 1 24th April 2010 08:31 PM
Car Audio Amplifier business made in USA boxcustom Car Audio 21 26th September 2009 12:30 PM
Page generated in 0.07964 seconds (84.55% PHP - 15.45% MySQL) with 10 queries
