#11 |
Small curvature on sinks without heat spreaders would not matter much
But you could ceck with a straigt edge (like stanley knife blade) shine same light on the back of it and have a look. To cek the whole sink you need some sort of realy flat surface Glass /Granite and a bit of oily ink rub the sink on the surface and the ink shows the hi spots. |
#12 |
RIP
The whole heatsink doesn't need to be perfectly flat, just where the fet sits. A good mill file will get you there with no trouble, just keep it clean while you are working it. Then you can polish it to perfection if you would like.
Best, Bill |
#13 |
| 3 inch Audio Nirvanah driver performance | ashok | Full Range | 1 | 2nd June 2011 12:03 AM |
| Can I run a 10 inch JL audio and a 12 inch JL audio off same amp | ash4kel | Car Audio | 2 | 8th April 2011 02:12 AM |
| Aleph2 Heatsink from HeatsinkUSA | kop89 | Pass Labs | 10 | 28th April 2009 03:14 PM |
| JL W3v3 10-inch or 12-inch? | bad1301forlife | Subwoofers | 1 | 1st April 2007 09:05 AM |
| 'Best' cost/simplicity/performance 10 W Single Ended Class A | npr | Pass Labs | 2 | 25th September 2006 09:48 AM |
