the a40 is a monoblock design but sharing the same chasis
on the left channel buzzing is high but on the right channel buzzing is very high. Both their ps are soft regulated by a caps multiplier. BUt a sawtooth waveform on the caps is present buzzing is really loud. For the jfet current source, only the resistor option is used .any ideas to help solve the problem |
#3 |
The one and only
It was quite common for people to get an N channel Jfet
(used in the current source which biases the two diodes which in turn bias the main current sources) which has a different pinout than the one used in the project. If this is the case, there will be excessive current through the Jfet and lots of ripple voltage will appear at the output of the amp. Check the current through the resistor Gate to Source on this Jfet and see if the current exceeds a few mA. If it does, replace the Jfet and confirm the proper current < 5 mA or so. |
#4 |
Don't know if you have the same problem, but i had a hum too, untill i used 2 bridge-rectifiers per PS.
Good luck Grtz Nick |
#5 |
tried caps across current source, used 2 bridge rectifier per ps must now try jfet current source, snubber network across the diodes, and try cap compensations. Does that help? i understand that is for low pass filter, changing to something bigger would roll off high frequency when feedback, can that reduce the buzzing
#7 |
sorry i meant the sawtooth on the rectifying cap. is around 0.2volts. Ripple after the caps multiplier is 25mv but sine wave.
#8 |
If you are running 2 transformers you might start with disconnecting power to one of them. I say this because
I had a simmilar problem when I used 2 transformers in the same chassis the other times I used a singlr transformer with no problems. If this stops the hum you may have some weird ground loops. If you still have the hum why not try the amp without the cap multipler ? Good luck, bob12345678 |
#9 |
without the cap multiplier buzz was there aready. Same level after inserting cap multiplier. would try disconnecting 1 trans. I have tried different grounding scheme, Inserting base resistor on the pin of output trans,lift and isolate ground via 10ohm and 0.1uf. When connecting cd player and preamp, buzz and hum increases. Could be bad wiring layout.
#10 |
I have (also) build a40 using two separate toroidal
transformers. Didn't work to use on ground point for the both power supplys. Very irritating buzzle noise appeared. So i builded them as two separate blocks in the same chassis. Works very fine. |
| Buzzing Pre-amp | stevebell | Solid State | 10 | 12th June 2008 03:26 PM |
| Buzzing noise on RF 250.2 | tavo04 | Car Audio | 15 | 12th February 2008 12:28 PM |
| SMPS buzzing????? | theAnonymous1 | Power Supplies | 5 | 14th August 2005 12:33 AM |
| Buzzing sound | Måsen | Digital Source | 0 | 13th March 2005 08:39 AM |
| Page generated in 0.10411 seconds (79.55% PHP - 20.45% MySQL) with 10 queries |
