I've populated two boards from the diy store with a kit bought elsewhere.
I know the parts are installed correctly except for maybe the pots for setting bias. Is there a certain polarity for these? Also I didn't install any thing in the led area as it's not necessary in my app. Should this make any difference? Doesn't look like it to me. I'm getting a dead short when plugging in one board with the dim bulb tester. I know the power supply is ok as I tested it with a good 3886 board and everything is as it should be. Can't find any mistakes on board and I have gone over it many times and all is correct. Frustrating as I'm ready to hear some good sounds. Any insight? |
#2 |
Regarding the trimmers you need to measure the resistance across R3 & R4; assuming they are the same as my cviller pcb's. Clockwise or anti depends on how you've installed them. Lots of info on all the other F5 threads.
#3 | |
F5 clone, Aleph J clone, Fostex 206 BLH, Altec/Onken, Behringer Digital Xover, Technics SP10 MKII & SL-1210. |
#4 | |
#5 | |
So if the bias is too high it will keep the bulb bright? I'll recheck all and check this point. |
#6 |
see marra's post for how to check your pots
#7 |
Sometimes a square peg fits a round hole just fine
yep, there are actual physical indications of the direction, albeit under the board
#8 |
Thanks for the help all.
Just the bias was causing my dbt to stay lit. It's playing now at a low bias but it does sound great. I've got a few more things to do with it before being complete but happy for now. |
#9 | |
Sounds even better after a couple of weeks use. |
| PCB Layout Questions | buzz1167 | Solid State | 24 | 9th October 2010 06:55 PM |
| FS - Cviller F5 | Neutrality | Swap Meet | 3 | 21st September 2010 09:51 AM |
| FS: Cviller F5 P.C.B with PSU | bchristmas | Swap Meet | 1 | 11th September 2010 02:16 AM |
| cviller f5 board Q5, Q6 orientation? | qboneus | Pass Labs | 2 | 19th August 2009 12:07 AM |
| PSU PCB Layout questions | cliffD | Digital Source | 0 | 25th May 2006 06:12 PM |
| Page generated in 0.10404 seconds (79.96% PHP - 20.04% MySQL) with 10 queries |
