The best FIRST WATT amplifier for my systeme
Old 15th May 2011, 05:01 PM   #1
EBA is offline EBA  France
Default The best FIRST WATT amplifier for my systeme
I'm interested to build two Nelson amplifiers. I rote all the informations of his site and i consulted this forum.
I'am not shure that the best amplifier is . I want your help.
My chose : F1J
Treble : T925 A. 6860 Hz to ..... sensibility : 108 db Nelson amplifier ? actualy SE 300B Verdier.
Mid range : IWATA 2 " + Radian PB 950. 305 Hz to 6860 Hz. Sensiblity 111 db. Nelson amplifier ? Actualy SE 845
Bass : ONKEN 360 + B15EX EMSPEAKER. 25 Hz to 305 Hz. Sensibility : 100db. SE 845
Driver before the amplifiers : DCX2496 modified + diy preamp ( BUF04 + tranfo LUNDAL, 14 db and out imp 600 ohm and prépré with SK170GR).
I search a clear sound with a best fidelity of the source.
Old 15th May 2011, 05:07 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I would pick an F2J for that.
Old 15th May 2011, 05:30 PM   #3
PeterDupont is offline PeterDupont  Denmark
Thanks, I have undamentally the same system. It is indeed very tricky to pinpoint the right amp in the line of many, many derivatives. This helped on the further path.
Regards, Peter
Old 16th May 2011, 06:30 PM   #4
Thanks NELSON for your reply and congratulation for your very good work.
I search informations for your F2J and i'm not found anathing to build it. Have you published informations about it?
Old 16th May 2011, 07:10 PM   #5
generg is offline generg  Germany
generg's Avatar
http://www.firstwatt.com/pdf/prod_f2_man.pdf
FIRST WATT F2J
DIY F2 clone
http://www.diyaudio.com/forums/pass-...-f2-j-fet.html
Good luck!
and the First Wtt is......a really First Class PSS Idea
Old 16th May 2011, 07:18 PM   #6
Thanks generg,
I'm beguining to work for build a F2J.
The best FIRST WATT amplifier for my systemeHide this!Advertise here!
SEWA - Seven Watt Amplifier Mad_K Pass Labs 938 6th May 2014 06:33 PM
2.1 systeme helpppppp aladin1994 Full Range 6 23rd March 2011 08:38 AM
connection from a pc to an electronic systeme nanofield20 Everything Else 2 14th September 2010 08:05 PM
150 WAtt amplifier ali_moinuddin Solid State 9 21st August 2008 01:12 PM
Clone SA2K systéme audio ;) mezzo Multi-Way 11 20th April 2003 09:36 PM
Copyright ©1999-2017 diyAudio
